Traction Control getting overzealous
Old Mar 28, 2012 | 06:53 PM
Cowboy6622's Avatar
Default Traction Control getting overzealous
Those who know me know I'm not a heavy foot kind of driver. I had my transmission serviced last October and ran the syntehtic fluid, and now the traciton control is getting a little over happy.
You can be sitting at a stop light or something, barelly pat the throttle, and it goes active. It never does anything at speed, just on take offs.
It seems to do it most when you've just recently put it in gear. Once it has been in gear awhile, it gets better.
I've read that it could be the speed control sensors? Think it coudl be something to do with the transmission?
Old Mar 29, 2012 | 12:22 AM
Mine did the same thing when I had a hub going bad. Mainly when i had the wheel cranked and then went to take off. After I replaced my hubs it quit.
Old Mar 29, 2012 | 08:03 AM
Most likely a hub
Old Apr 1, 2012 | 08:21 PM
04chevyboy's Avatar
ive replaced both my fronts and its still going on,..
Old Apr 1, 2012 | 08:33 PM
Cowboy6622's Avatar
My car has actually started behaving since I started threatening to just get rid of it next year.
Old Apr 1, 2012 | 08:50 PM
It's allergic to the ovals.
Old Apr 1, 2012 | 09:03 PM
Cowboy6622's Avatar
It's not even around the ovals 5 days a week....
ACtually, it does park beside my roommates Mustang those 5 days and across the way from three Fords on weekends....
Old Apr 1, 2012 | 09:37 PM
boggie's Avatar
replace the hubs or the speed sensor harness is broken some were along the line and shorting out
Old Apr 1, 2012 | 09:53 PM
I replaced both hubs on wife's 2005 Impala SS, They both had play in them., The light still came on ..,Then I replaced the abs wire going to the hub and that fixed the problem..
Old Jun 29, 2012 | 09:31 PM
mini64's Avatar
hubs didnt fix mine either. neither did replacing the ground strap to the controller. but what did was replacing the cables going to the hubs. bought two dorman 970-040 abs sensor harnesses from amazon and now the problem is gone!
mwmarshall
May 14, 2022 02:43 AM
Anna
Jan 13, 2013 03:36 PM
Jul 8, 2012 08:27 AM
callie100
Oct 23, 2011 07:08 AM
Sciggy
Dec 18, 2007 01:35 PM
