TPS Low Circuit?
Old Jan 21, 2012 | 01:50 PM
jwjones's Avatar
Default TPS Low Circuit?
I just replaced this damn sensor 2 weeks ago and the car is acting up again and threw an service engine light. What the hell??? I just inspected the sensor and all looks good, where do I turn now?
Old Jan 21, 2012 | 10:42 PM
nitehawkjcb's Avatar
The throttle position sensor? Make sure you installed it correctly - you have to sit it down in there and twist, then screw it in.
Other than that, check the wiring going to & from the connector.
Old Jan 21, 2012 | 11:25 PM
SupplySgt's Avatar
Yeah check the wiring. Everything between the fuse boxes and the sensors and the ECM. Be a good time to check the rest of your wiring while you're at it to head off any potential issues that haven't reared their ugly head yet. Wiring is a b**** but sometimes it's just gotta be done.
Old Jan 22, 2012 | 12:26 AM
jwjones's Avatar
Went outside and removed it and installed it once again and started the car and the light turned off. idk if it was wiring or the sensor not installed properly but seems to be working fine now
Old Jan 22, 2012 | 12:30 AM
SupplySgt's Avatar
May have been an iffy connection where you snap it in.
Old Jan 22, 2012 | 10:57 AM
Sounds like you got it figured out.....
But I would also ck the connecting wires to be sure proper instahllation wasnt the only issue...Just to be safe...
Tzarm
Oct 9, 2013 03:36 PM
EJFX
Jul 24, 2013 04:09 AM
moneycarlo
Nov 7, 2008 03:24 PM
hot95mcz34
Apr 20, 2008 10:03 AM
shawner
Mar 8, 2006 08:49 PM
