top speed
Old Feb 28, 2008 | 08:46 AM
04 Intimidator's Avatar
Default RE: top speed
ORIGINAL: mrl390
Lav, 154 is the ungoverned top speed of the 06/07 years. Obviously there was no L67 for those years.
I think he was reffering to the 2nd post where it said all Monte's.
I can't see a L67 breaking 140-145ish stock. Maybe if there wasa long flatway and you could run it out.
Old Feb 28, 2008 | 09:13 AM
tlip06's Avatar
I don't see how anyone with a stock monte carlo (00-05) can go above 110-112 in a stock monte.
I have a supercharged monte and my govern is on and it stops EVERYTIME at 110-112.
The only way you can go over that speed is if you have the govern taken off or you get a PCM or something.
I have tried and tried to gofaster than that but it doesn't work it just stays at 110-112 EVERYTIME.
It's just hard to believe that anyone with this car can go faster than that unless u bought it used and someone got a PCM flash, removed the governor or something of that nature.
VERY VERY HARD TO BELIEVE
Old Feb 28, 2008 | 10:29 AM
ORIGINAL: tlip06
That is true. I was refering to ungoverned. You would need a simple programmer like Hypertech (not recommended) just to remove the governer. No other mods.
Old Feb 28, 2008 | 11:21 AM
kweef's Avatar
mine goes all the way to 126 if i dont have it reprogrammed at all...just have to find a long enough straight away
Old Feb 28, 2008 | 11:26 AM
tlip06's Avatar
I mean I-480 is a long straight away. like i said before i have maxed my car out a lot. i never go over 112. i have held that same speed for about 30 seconds and it won't go over.
i don't know why they would make the same car but some of them are faster than others expecially because my car is supercharged. it just doesn't sound right.
Old Feb 28, 2008 | 01:14 PM
Cowboy6622's Avatar
i ahd mine retuned....
Old Feb 28, 2008 | 04:38 PM
2 quick4u's Avatar
Take it to a dyno shop have your pcm reflash $350.00 and then you can do 126 MPH and then 4 grand for a motor, now that is a good reward for doing 126 MPH. and you might get a funeral to boot for $350.00 now that is not a bad trade off.[sm=dontgetit.gif][sm=signs003.gif]but doing 70 mph will accomplished the same. Everyone has there way of doing things different.
Old Feb 28, 2008 | 06:26 PM
2000_BLACK_SS's Avatar
i have never had my pcm flashed or any programmer on it and i have hit 125 with the mods that are on my car right now
Old Feb 29, 2008 | 12:29 AM
kweef's Avatar
ORIGINAL: tlip06
could it have sumtin to do wit the tranny? maybe they set it lower to protect the tranny at high speeds
Old Mar 4, 2008 | 02:52 PM
06MonteSS's Avatar
... the 06/07 SS's have an ungoverned top speed of 154mph...
the 06/07 SS's have their speed limiter in the ECM tune set to 142mph...
I know... I've been in the tune file, and upped mine to 160...
