Tires Squeal
Old Oct 28, 2007 | 11:58 PM
FlynhghR's Avatar
Default RE: Tires Squeal
Couch, what do you think of the coopers, and which model did you get? I got the performance rated ones (like the highest model)... and they were nice at first, but man did they wear quickly!Sure that is compared to stocks,,, but shees, I ran through em in like 25k!
Old Oct 29, 2007 | 08:39 AM
cain45's Avatar
Mine squel horribly too. Mine are the Goodyear Eagle LS2's and they suck. In rain they will slide too. If I was keeping it I'd put Michelin's on it, but I'm not cause it's going bye bye soon.
Old Oct 29, 2007 | 11:43 AM
Mrrench's Avatar
Have you checked the alingment. Sometimes that will cause them to squeal when making turns as well.
So far I have no complaints with my Goodyears......
They dont squeal unless if I go around a turn to hard. Yes they will slid on wet roads but found common sense solves that problem. Know when to hit the gas hard and when not too.......
Old Oct 29, 2007 | 06:32 PM
nix06monte's Avatar
well it could have been the pressure
they were all in the upper 20s
see how that worked
Old Oct 30, 2007 | 12:20 PM
rj's Avatar
rj
At 27/28 psi my tire montior system starts flashing, "Check tire pressure" across the speedometer.
Old Oct 31, 2007 | 09:50 AM
cain45's Avatar
Well mrrench is has nothing to do with common sense, since my new Michelin's don't have this problem whatsoever!
Old Nov 1, 2007 | 11:26 AM
Mrrench's Avatar
That must mean you are keeping your Monte cause you put Michelins on her..... or did you put Michelins on something else....
Old Nov 11, 2007 | 06:16 PM
04 Intimidator's Avatar
Solara was right on the money. Under inflashion causes extra movement on the rubber and the harder compound doesn't grip as well.
I'm going with Goodyear TripleTreds really soon. After my last drag race I can see belts where I wore all the rubber off.
Old Nov 11, 2007 | 10:06 PM
cain45's Avatar
Put Michelin's on my Blazer as the Monte is going "BYE BYE".
jford61
Aug 11, 2013 07:50 PM
jhbasse
Jan 15, 2013 06:39 PM
Osiris
Dec 29, 2012 03:48 PM
DRuben
Sep 12, 2011 11:57 PM
MonteLSV6
Dec 24, 2010 10:19 PM
