timing videos
Old Mar 9, 2013 | 06:52 AM
Dam20735's Avatar
Default timing videos
are there any videos step by step showing how to set the time when using a double roller timing chain on a 3800 supercharged motor or at lease a few steps
Old Mar 10, 2013 | 11:21 AM
turbo monte's Avatar
i dont know of any videos but i have pics that will show you
first thing you do before installing the new timing set is make sure cylinder 1 piston is at top dead center!!
as you can see in this picture you want the crank gear (bottom gear) installed so the (0) is facing up (toward the cam gear) and on the cam gear you want the dot facing down toward the crank gear. the (0) and the dot should line up with each other.
you will also want to buy a new crank and cam bolt as well
GM ACDelco - Crankshaft Bolt #GM-24504736
GM ACDelco - Camshaft Bolt #GM-24501366
also it is a good idea to have the gears machined to fit true to the block. (barnas performance machine is who did mine)
you will also want to buy a machined oil pump cover.
ZZPerformance - Machined Oil Pump Cover #ZZ-OILPCVR
hope this info helps you out
Old Mar 11, 2013 | 03:06 AM
Dam20735's Avatar
thanks yes it helped my timing was off an i wen to try an drive my car after installing the cam an the flywheel studs broke off an i bent a pushrod so i got a whole new motor hopefully everything works out now thanks for the help an my sprocket didnt have anytype of timing mark at all
Old Mar 11, 2013 | 07:51 AM
What kind of timing set was it?
Old Mar 12, 2013 | 08:21 AM
Dam20735's Avatar
Jp performance
Old Mar 12, 2013 | 08:55 AM
I would recommend getting a roll master timing set. I remember hearing a lot of stories about the jp timing set breaking. I am using the roll master.
Dam20735
May 23, 2013 04:09 PM
BeachBumMike
May 31, 2007 09:31 PM
76MonteMan
May 13, 2007 04:13 PM
LittleMT
Dec 8, 2006 01:16 AM
monte83
Jun 17, 2006 02:36 PM
