Timing issue
Old May 19, 2013 | 11:44 AM
Dam20735's Avatar
Default Timing issue
Ok I have found the main two of my problems of my timing one my magnet is messed up two my timing might be off just a Lil so in this diagram can somebody tell me which one i should use
Old May 19, 2013 | 11:45 AM
Dam20735's Avatar
That's the double roller master which 0 do I use based off the diagram
Old May 19, 2013 | 02:19 PM
Have you used the "Standard" timeing setup?
Is it all stock? If it is use the Standard setting.
Old May 19, 2013 | 05:23 PM
turbo monte's Avatar
did you buy a roll master instead of a jp? here is a link of why to not use a jp timing set!
IMPORTANT: JP Roller issues - Grand Prix Net
now answer to your question, the "0" on the sprocket tooth points straight up to the cam gear mark. which should put the other "0" that is closer to the center by the keyway on the crankshaft. note link to pic below
https://www.google.com/search?q=3800...l%3B1008%3B756
Dam20735
May 23, 2013 04:09 PM
thtGuy
May 7, 2013 08:09 AM
fedspunisher
Nov 12, 2006 06:52 PM
tiny4lx
May 16, 2006 06:55 PM
Cainius
Jan 16, 2006 02:02 AM
