Tighten gas cap
I bought a new GM gas cap 2 weeks ago before leaving for Fla. As soon as I put it on , a mile later CE light went back off. Now the stupid light is on again and keep seeing message tighten gas cap. I have that thing tight. Should I just take that one back and get another or is there an easy solution to this problem. CEL being on drives me crazy. Then if you have a real problem and it was already lit, you'd never know.
I'll have to keep an eye on this thread in case somebody has an answer my grandma has a 2001 Ford Escape, after a month or two of owning it the engine light came on, went the Wilbur Ford and found out it was the gas cap. So she got a new one...3 times within two months time, she gave up and the light has been on for pretty much 10 years now, everytime I go to drive it it drives me crazy but it runs fine.
I think I already encountered this problem before. As far as I can remember, what I did before to fix this "tighten gas cap" message is that I turned off the car first, disconnected the battery by removing the negative terminal. Then I waited for a few seconds then I reattached it. Then I started the car and then that cleared it. If it doesn't work then bring it to your dealer. It still got warranty.
