For Those Like Me Who Are On A Budget
Well, I've got a little Gizmo (ScanguageII) that'll give me a reading of the the air intake temperature while I'm driving. I'll watch the readings when I leave work today and post the results. I'll be interesting to see the difference between outside air temps and intake air temps on a stock setup. Oh, and it's 91 degrees outside now, so there's no shortage of hot air available!
I've been curious too, I never took IAT readings before I switched to the wizaid CAI
No, I was dumb enough to include a blatant swear word in the title. I need to read the rules.
How about $45 total delivered to your front door?
Right now, you're shooting yourself in the foot IMO. Sure you've got a little more air filter surface area; and you've given it less restriction to air coming in- but then you added metal pipe to the intake (heat soaks)- and put the filter right in the middle of a hot engine bay. Sure it may be in front of the original intake's hole- but how much air really comes through that hole- especially if its not running at below ambient pressure (like it would be stock sucking through it)? Then compare that to the volume of air moving through your radiator via the fans (think about where that air goes- slams into the front of the engine, and is forced off to the sides and top of the engine bay- right into your filter. There is reason why OEM's are getting away from metal intake piping (and metal intake manifolds) and also haven't used underhood air induction in years.
While it isnt shielded, it does draw from the same place that the stock airbox did.
If you dont have the bread for all the mods you want, this is a phenomenal buy that can free up cash for other fun things.
Personally, if you're tight on money; I'd rather just buy a regular $10 replacement filter and leave it at that. Less install hassle, same performance, and you'd save $35 for gas or something.
Unfortunately, buying the enclosed version or adding piping (the filter is already very close to the spot where a pipe would go, and I wonder how much of an improvement in perf you would get restricting air plow thru a small tube like the stock box did) is the antithesis of ballin on a budget.
The filter is a monster. Its at least twice the size of the opening that the stock box breathed thru. The best I could do was aim the filter directly at said opening with about a 1" space from the lip that restricts further movement.
One must also factor in that my car is an automatic two-ton front wheel drive, non supercharged V6. How much power improvement are you really gonna feel in a car like that?
Well, I was informed via PM that members (with an s! more than one!) were offended of my use of a slang word commonly attributed to someone who is flashy rich and/or a highly paid pro athlete.
Confused? So was I. Thank goodness they were good enough to include a link to urbandictionary. When you have the time, visit that informative site, enter in that certain B word, read the definitions they have, and let the lulz ensue.
Bumpin96monte, i dont know man. I havent noticed any power loss at all. I have noticed my 'masters sound better than they did with the OEM. I guess ill replace the metal pipe.
Doesnt K&N still use shielded, but not enclosed filters? Even for that big LS4? Doesnt seem like that would help the pressure or airflow prob. Then again Im a drunken monkey right now, so maybe it does.
Intake air temp readings I promised (stock setup). Highway - outside air temp was about 86, Intake air reading was 92. In traffic much worse - outside temp 82 - intake air reading 100-110. Much of that increase is probably heat from the cars around me and the pavement, but how much I don't know. Max water temp 207, tranny 204.
