Standard Exhaust Improvement Minus the expense.
Ok I have been throwing around a few Ideas inmy brain about my exhaust.
My Z-34 new came with catback duals...with walker mufflers... They have been worn out long ago and replaced with "turbo" mufflers..(to quiet for me)
So, I have been searching for an alternative without spending a fortune or doing a complete make over of my exhaust...( Limited Budget Expenses)
Heres a cpl of things I have considered:
Do a Muffler delete/ straight pipes with or without resinator..plus tails and tips.
Do a non Muffler delete/ insert glass pack where resinator was in stock position with tails and tips.
Do Muffler delete/ Insert glasspack in resinator(stock) position and tails and tips.
Replace Mufflers with ?? cheap ?? mufflers/ delete resonator/ add tails and tips.
Since this is going to more than likely be the last time I will have or want to mess with the exhaust/ Its not a racing type setup vehicle HENCE:/ non supercharged/non turbo type..
go fast vehicle...merely a daily driver that I would like to add a little "Tone" to it.
So, im lookn for a little input here as to a non expensive way to improve its tone of voice. (Remember this will be the mrs daily driver again after the Monte Nationals) She doesnt appreciate a little tone in any vehicle.![ROTFL](https://montecarloforum.com/forum/images/smilies/lmao.gif)
Thanks in advance for any and all input....
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
I removed the resonator on mine. Just put a straight pipe in. The rest of my exhaust is stock. Made it a little louder, and made the pitch a little higher. Not a huge fan of it, but it's cheap.
Cowboy6622 Duane ran his N/A 3800 with no mufflers for a while. At first he liked it. But eventually got tired of it. I'll let him explain further.
You're not going to get it to sound like a big V8 engine. It'll always sound like a V6. But you have lots of choices for changing the tone and volume.
I'd be afraid of it sounding ricey though. Which is why I'm not really liking removing the resonator on my Monte. To me it sounds borderline rice. But that's just my opinion.
Also he didnt have any sort of tips or room for atils and tips..they were just to long...
Thanks Wayne!
No mufflers is going to drive you crazy. The 3800 sounds terrible loud.
I have a Magnaflow Resonator with Magnaflow mufflers (because I have the now discontinued GMPP Cat-Back, which was just an unbranded Magnaflow). I like it, it's not TOO loud
I realize (which is obvious) It'll never sound like a V8....But its to friggn quiet for me LOL....I did stop today at 1 of the exhaust shops that I usually have my exhaust work done at.. He suggested the samething...
I also found on you tube a 3.8 that had his exhaust done the same way
and it was a little raspy ... But wasnt to awful sounding either...
Thanks Taz!
What did that setup cost?...Im kinda Money shy now that the mrs is off work...So, Im definately on a tight budget til we get caught up again...
She goes back to the doc on friday for a check up after her procedure...
Since she gets paid by weekly....were a little strapped for cash...
Thanks Mike for the help!
Right now thats a little bit more than I am able scrounge up at this time....
But most certainly, Should I get to the point that I need to replace the whole system.. I wil definately consider it!
Thanks Mike.
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
I'd put on 2 Magnaflow mufflers with a 16-18" Magnaflow glass-pack, essentially making the GMPP system, just without the high cost. Then add some nice stainless tips if you don't already have them.
Basically that's what I did on my 3.4, although I'm not changing the stock res until spring, I've currently just got it patched as it split again. Only difference is the 3.4 sounds a little, well... better than the 3.8, but they're along the same lines.
