Slipping belt sound. Transmission maybe?
Old Mar 9, 2009 | 02:12 PM
garbear's Avatar
Default Slipping belt sound. Transmission maybe?
2001 Monte LS. I started to hear a noise that sounded like the belt slipping when I would put my foot in it to pass someone etc. It sounded like the belt slipping so that's what I went with. I found that the power steering pump shaft seal was leaking and starting to sling oil. I changed the pump, cleaned everything up, ran the old belt for a week to make sure all the oil was gone before I put a new one on. I put the new belt on and it still makes that noise when I get on it. Has anybody had this problem? I also changed the tranny fluid, filter and disconnected the return line at the tranny and flushed 4 extra quarts thru it. There was nothing but powder on the magnet and a few tiny brass flakes in the pan. The transmission acts normal but I'm wondering if something is getting ready to go. This is my first post on this forum, I appreciate any feedback. Thanks.
Old Mar 9, 2009 | 02:34 PM
wiz kidd's Avatar
some people will completely dissagree with me, and some people wont, but i talked to a few tranny guys around here and they said never to do a complete flush on the system as it stir's all the crap around thats sitting in there, doesn't get rid of it, just stirs it up and causes problems. now i know some people will start saying NOT TRUE!! but it is, i've talked to a few people that have done flushes and this is what happened shortly after is that it screwed up their tranny....in short, if your tranny is ok, i would never recomend doing a flush again...just drop the pan and fill the fluid up
i really do hope its not your tranny though
Old Mar 9, 2009 | 03:00 PM
garbear's Avatar
I couldn't stop myself from trying to get a little more old fluid out of my tranny. I limited it to a 4 qt. flush by only buying a case of tranny fluid though. Anyway, it doesn't shift funny before or after the fluid change. I just get a slipping belt type sound when I kick it down a gear and I'm 99% sure it's not my belt. Last spring my BCM went south and I'm wondering if my tranny is going to join it this spring. Thanks for the comeback.
Old Mar 10, 2009 | 02:50 PM
kweef's Avatar
hmm just because ur belt is squeeking doesnt mean that it is the belts fault. did u look at the of the pulleys when u took it off? how about if the belt is tracking correctly? one of the pulleys may have slightly moved and affected the traction? get urself a pair of sonic ears(not sure if thats what they are called) have sumone reve the car and get a better idea of where to noise is coming from
Old Mar 10, 2009 | 04:14 PM
I agree with whiz kidd - statistically alot of transmission flushes result in tranny failure, but this may not be coincidence either. I wonder what percentage of tranny flushes/ services are done when people "start to feel something funny"? But I know what you mean and am hesitant to dick with mine ever.
Old Mar 10, 2009 | 05:50 PM
wiz kidd's Avatar
check into getting a dayco poly rib belt, not poly cog, its a new design they have now to eliminate squeeking...works really well...but yes it could be a lot of stuff
bignasty
18
May 31, 2022 07:40 PM
Backinblack
Feb 28, 2012 12:29 AM
1WX27
Jun 30, 2008 03:24 PM
mrl390
Apr 19, 2008 08:57 AM
STL_CHeVY_RiDeR
Jan 18, 2008 12:53 AM
