6th Gen ('00-'05): slight shake at 60 mph
Old Sep 12, 2014 | 02:51 AM
claydoh's Avatar
Default slight shake at 60 mph
I have a slight shake at around 60 mph,I have replaced both front wheel hubs,front end checked and aligned,brand new tires.wheels do not seem bent according to tire shop.could this be caused by bad cv joints? or even the top motor mounts/bushings??
Old Sep 12, 2014 | 06:19 AM
Sounds like tire balance. Its a good idea to have more than one tire shop check 'em. I had my tires balance 4 times before someone got it right
Old Sep 12, 2014 | 06:24 AM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
Yes to all, though I'd suspect the axle as the culprit. Even if the boots are intact and there isn't any noticeable "popping" as happenes a lot of times when one of the cv joints is bad. It don't take much slop to cause a vibration. I've seen the inner part actually be worse than the outer prob 90% of the time.
Any time I replace hubs on these cars these days I put new axles in while I'm at it. Heck you are already right there with everything tore apart, only takes another 10 minutes and 150 $ or so.
You might get lucky as jr said and have a wheel out of balance. Look and see if you see any wheel weights noticeably missing.
Old Sep 14, 2014 | 01:31 AM
claydoh's Avatar
thanks for the replies! I haven't replaced the rear hubs yet,still getting traction,ABS lights while driving, now very frequently and once it lights up and dings and stays on the problem stops! gotta get the code read. cand bad torque thrust motor mount bushings cause a shake? gonna change these as well,they are cheap!??? thank you!! claydoh
Nov 16, 2014 07:06 AM
Peter W. Ruby Sr.
Nov 11, 2014 07:37 PM
MayoJ1
Jul 2, 2012 09:29 AM
lougreen03
May 24, 2011 08:33 PM
White05LT
Aug 14, 2008 03:01 PM
