shift kits?
Old Feb 26, 2007 | 08:18 PM
2000_BLACK_SS's Avatar
Default RE: shift kits?
People have always said if you get a shift kit to becarefull about which PCM upgrade you get and the w-body store one is the only one that seems mild enough to still be able to have a PCM upgrade and not have to worry about messing up the trany.
Old Feb 26, 2007 | 08:27 PM
mickey's Avatar
Oic see what your saying now, slow sometimes
what they are talking about is some of the pcm upgrades will allow you to change the trans. presure to make the car shift harder/faster. what they are telling you is not to have both at the same time.
exampel
in the hypertech computer you can change your line presure to 25% 50% belive it is 100% harder then stock
If you have ashift kit it changes the peramitors from you stock trans. already so DO NOT DO BOTH!!
It will result in Damage to your tranny. it will cause it to shift WAY to hard and could cause breakage in the tranny and also could cause other things to fail like gaskets etc..
but the Thrasher kit will work with the pcm you have and if you buy the programer you just make sure you dont reset the trans presures to be diffrent then what they are stock
02 Earnhardt Monte Carlo SS
39
Nov 17, 2014 06:16 AM
86hazelmonte
Feb 10, 2014 07:42 AM
MonteNoob
Jul 19, 2009 11:44 PM
thatrealcreolenigg
Sep 28, 2007 08:05 PM
mickey
Aug 17, 2005 05:16 AM
