shakey monte carlo! help!
Old Dec 17, 2010 | 03:42 PM
my00monte's Avatar
Default shakey monte carlo! help!
I just noticed today that when I get to about 60mph or faster, my car starts to shake. I really just noticed it on the steering wheel. I was thinking it might be one of the wheels out of line or low on pressure, but I'm not sure. Help please!
Old Dec 17, 2010 | 03:53 PM
zipper's Avatar
How's the tread on your tires?
Also, one of your struts might be bad too. If you push down on the back bumper and the Monte does one bounce and stops, the back ones are good. If it keeps going then it's likely one or both are out. Repeat the test for the front.
Old Dec 17, 2010 | 04:19 PM
Enzo354's Avatar
STILL SLOW
Lol check the tire pressure then? Then go get the tires balanced, you probably hit a pothole and it screwed it up.
Old Dec 17, 2010 | 05:33 PM
Overdose666's Avatar
I had that same problem, just had to get the tires balanced
Old Dec 17, 2010 | 06:47 PM
Budsjlm's Avatar
i see your in iowa any snow storms lately? if so go hit the local self serve car wash and spray your rims may be ice/snow build up on your rims, if not bring it to a tire shop and have them balence them
Old Dec 17, 2010 | 07:32 PM
i would get them balanced, i had the same problem, and it got really bad at the 90-100 range, got them balanced and now no problem
Old Dec 17, 2010 | 11:54 PM
my00monte's Avatar
so it seems like i just need to get them balanced? i checked to tread on my tires and they look fine.
Old Dec 18, 2010 | 12:16 AM
yeah, if you bought them some time ago and never got them rebalanced that usually causes the issue, i'd check to see if they have lifetime balancing if you bought them after the car
jaydflash
Aug 29, 2014 03:38 AM
mwjames
Oct 11, 2011 12:04 PM
cj702
Aug 20, 2006 03:20 AM
