Seems like no one knows the answer to this question
Old Jul 26, 2012 | 10:07 PM
16With01MonteSS's Avatar
Default Seems like no one knows the answer to this question
I already have a aftermarket JVC Stereo but i am now planning on upgrading to a touch screen stereo.. will i have to buy a new wiring harness and antenna adapter. or can i use the same one that i already have on my jvc on the touch screen im buying?
Old Jul 27, 2012 | 12:16 AM
Enzo354's Avatar
STILL SLOW
See what each requires and compare the part #'s
Old Jul 27, 2012 | 08:35 PM
Habbibie's Avatar
Is the touch screen also a JVC?
Old Jul 27, 2012 | 09:11 PM
01 Monte SS's Avatar
You should be able to re-use both. The antenna adapter is easily reusable. For the wiring harness you'll probably have to cut the wires and connect them to the new stereo's wires.
Old Jul 27, 2012 | 09:36 PM
You CAN reuse them both. You'll probably just need the mounting kit
Old Jul 28, 2012 | 08:14 PM
<TABLE id=post481441 class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center itxtNodeId="386" itxtHarvested="0"><TBODY itxtNodeId="387" itxtHarvested="0"><TR itxtNodeId="389" itxtHarvested="0"><TD style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=alt2 itxtNodeId="405" itxtHarvested="0"><TABLE border=0 cellSpacing=6 cellPadding=0 width="100%" itxtNodeId="406" itxtHarvested="0"><TBODY itxtNodeId="407" itxtHarvested="0"><TR itxtNodeId="408" itxtHarvested="0"><TD noWrap itxtNodeId="411" itxtHarvested="0">16With01MonteSS <SCRIPT type=text/javascript itxtBad="1" itxtNodeId="415"> vbmenu_register("postmenu_481441", true); </SCRIPT>
Garage is empty, add now
</TD><TD width="100%" itxtNodeId="410" itxtHarvested="0"></TD><TD vAlign=top noWrap itxtNodeId="409" itxtHarvested="0">Join Date: Mar 2012
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR itxtNodeId="388" itxtHarvested="0"><TD id=td_post_481441 class=alt1 itxtNodeId="426" itxtHarvested="0"><!-- message, attachments, sig --><!-- icon and title --> Seems like no one knows the answer to this question ?
It seems like a few member's knew & posted
Also check with the touch screen manufacturer to see `if they are compatible. Good Luck.
Thanks Member's 4 your help & posts...
joeykl66
Feb 11, 2013 06:14 PM
jshladwig
Sep 6, 2011 07:48 PM
Jan 10, 2010 08:38 PM
