Sea foam engine cleaner
Old Sep 6, 2007 | 08:49 PM
2000_BLACK_SS's Avatar
Default Sea foam engine cleaner
i just bought a can off this stuff and then i was looking through the set of manuals i have and i cant find where the vacum line.
So can somebody tell me where the vacum line is or take a pic of it?
Old Sep 6, 2007 | 09:36 PM
HyperFox's Avatar
Default RE: Sea foam engine cleaner
Sure. You put it into the vacum line running from the brake booster to the engine. On the left side of the booster, if i am right.
Old Sep 8, 2007 | 01:20 AM
What does this look like i am thinking it is a black rubber tube that is about 1/4 of an inch in diameter that connects to a selenoid infront of the throttle body?
Old Sep 8, 2007 | 07:06 AM
wiz kidd's Avatar
you want to pull the rubber hose and the connector(usually plastic) thats going into the brake booster (big black round metal thing on the drivers side of your car, sticcking through the firewall) you'll see the hose, pull it off while the vehicle is running and stick the hose into the can and tip shut vehicle off for 10 to 15 min then watch the smoke show when you start it back up
make sure the vehicle is hot when you start to run it through too
Old Sep 8, 2007 | 11:44 AM
is this the right line ( iam thinking it is becasue it is the only one i see go into the brake booster)
<a href="http://photobucket.com" target="_blank"><img src="http://i185.photobucket.com/albums/x...AKEBOOSTER.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Old Sep 8, 2007 | 12:46 PM
I just tried to do this and anytime i went to remove the vacume line the car would die and if i tried to start the car without the vacume line it would start for a second then die?
am i doing something wrong or what?
Old Sep 8, 2007 | 01:14 PM
wiz kidd's Avatar
nope thats the right one, sometimes its hard to keep the car running when your putting it in, and when you go to start the vehicle when your done, it may take a few tries, but it will start, if you have a buddy there to help you have him start it while you got your finger over the hose, you may have to have him rev it (just a little) when it sounds like its going to stall
Old Sep 9, 2007 | 02:42 PM
THIS STUFF IS AMAZING
i would recomend buying it and using it as soon as possible.
I had a little movement in my idol before and now that is completly gone the neddle does not move at all.
and my engine is so quite now it is amazing
also the car seems smoother on acceleration
P.S. also the smoke show was cool to
Old Sep 9, 2007 | 02:58 PM
[:-]Great Endorsement for "SeaFoam" [:-]
Happy 2 Read that everything worked out, & your
Monte Carlo seems `Happy 2
Sounds like you are ready to Race : )
EnJoy your `Journey in your Monte Carlo,
`Space
773 Z34
Jan 19, 2013 06:10 PM
brettmonte
Oct 7, 2010 08:42 AM
bigdomvegas
Mar 2, 2010 12:50 PM
Evil03SSCarloGuy
21
Apr 29, 2008 07:10 AM
04MonteLS
Jun 5, 2005 04:02 PM
