Removing Stock Side Skirts and Door Panels
Old Jan 10, 2008 | 10:28 AM
FinkenZ34's Avatar
Photobucket
Default Removing Stock Side Skirts and Door Panels
Hey guys I'm installing the RK Sport Body Kit on my monte and i was just wondering do any of you know how to take off the stock side skirts and door panels, and have any of you ever done this kit before? Thanks for the help
Old Jan 11, 2008 | 11:36 PM
FlynhghR's Avatar
Default RE: Removing Stock Side Skirts and Door Panels
Probably just a bunch of body panel clips... I know when I had the rocker repaired on my 03 ls they had to replace a couple because they're easy to break. How does the new kit attach? The door panel might just be glued on for both though.
See if their website of the body kit manuf. has downloadable instructions... lots of sites have stuff like that, which can be a real help when trying to prepare for putting it on.
Old Jan 11, 2008 | 11:44 PM
FinkenZ34's Avatar
Photobucket
Thanks, i got the kit on the otehr day, if you wanna check it out its in the general section.
And for just general info, yes the side skirts are taken off with about 8-10 clips udner the car, and screws in the wheel well, and then it has pop clips inseide the door, real pita, but it'll come off
Old Jan 12, 2008 | 12:04 AM
FlynhghR's Avatar
Ahh, as I figgured. Sorry the help didn't come sooner! Not a lot of body ppl on here, quite a few mechanics tho... wether they're trained and working or simply backyard tinkerers there's lots of ppl here that are smart about the mechanical side of things.
I've been trying to decide wether to paint, or replace my side skirts... did you break any in the removal of ur stock piece?
Old Jan 12, 2008 | 12:20 AM
FinkenZ34's Avatar
Photobucket
The clips yes, about three or four each side, but i wasn't reusing them so it wasn't a problem
Old Jan 12, 2008 | 12:22 AM
red06SS's Avatar
I am putting the razzi kit on my car in about a month. One option you could consider is buying my SS ground effects. If you paint the stock ground effects when you get rock chips it will be the original color of the ground effects that shows through.
Old Jan 12, 2008 | 12:25 AM
FinkenZ34's Avatar
Photobucket
Ya the RK kit was black urethane so if/when it does chip, shouldn't cuz i got some pretty good apint, and lots of coats, it shouldn't show
Check out your one psot about the RK kit for your car, i posted int there too
Old Jan 12, 2008 | 07:59 PM
FlynhghR's Avatar
How much would you want for the factory FX? I've always thought about going to those, and I wouldn't worry about rock chips etc. I would use a matte paint job and cover it with 3m paint protector tape to prevent chips etc. Same stuff they use on the rolled under portions of truck fenders so the paint doesn't all come off due to rock chips.
I don't think I could make it out to wyoming to pick it up, so I wonder how much shipping would be on top... hmmm
Old Jan 12, 2008 | 08:05 PM
FinkenZ34's Avatar
Photobucket
I don't think my stock side skirts would fit ur car??? Cuz you have a sixth gen monte?
Also i only took off the side skrits and door panels, the rest stayed on cuz the FX just attached to the stock stuff
SuperSportSS
Oct 15, 2013 01:10 AM
Johnny562
Aug 18, 2011 08:50 PM
cali2000ss
May 26, 2011 10:43 AM
indytruder
Feb 15, 2009 03:50 PM
zchevroletman91
Feb 12, 2009 04:02 PM
