6th Gen ('00-'05): Radio issue
Old Apr 1, 2019 | 11:53 PM
01monte_project's Avatar
Default Radio issue
I have a question I have a 2001 Monte Carlo and I知 trying to figure out why I知 not getting enough power to turn on my radio all the lights in the dash work my radio just isn稚 turning on how do I fix this ?
Old Apr 3, 2019 | 10:02 PM
Skatulaki's Avatar
Have you checked the fuse box? there is a fuse for the radio in the fuse box ! Also have you checked for the 12V power into the radio? ( usually the biggest wire )
If you have been doing some dash work, it is very possible you have pinched a wire ! If you have power into the radio, the radio itself could have a problem.
I have repaired copy machines for 30 years so electrical problems are something I am well versed on. I have created some by pinching wires myself.
let me know if you need more advanced help.
Old Apr 4, 2019 | 05:33 PM
Well the issue is I知 not getting enough power like the wires were checked for power but I知 getting low power I知 trying to figure it out before it goes to the audio shop Monday
Old Apr 4, 2019 | 07:30 PM
Skatulaki's Avatar
Too many unknown factors : Is it factory radio or after market? Have you tested the radio separately? When you tested your wires, did you have the radio connected or disconnected?
Generally speaking you want to test the wires with the connector unplugged from the radio to get a true source read, the speaker wires shouldn't read anything. At least one 12 V and 1 ground, but there could be more depending on how its designed, and now days with more computerization, there could be 5V 10V and 24 V. You would need a wiring diagram.
If you have a pinched, or shorted wire, it should blow the fuse. If you check the wires with the radio disconnected and then with it connected and they are different, then its possibly the radio itself.
I just dont have enough information to go on, as to what you have or have not done.
Scott_S
Apr 10, 2016 03:42 PM
avendo
May 18, 2015 06:52 AM
carlohog
Nov 4, 2011 10:54 AM
labnjab
Aug 17, 2010 12:49 PM
paintballerr78
13
Jan 12, 2010 08:54 AM
