Radiator Drain Plug Question
Old Aug 31, 2010 | 01:38 PM
krakabash's Avatar
Default Radiator Drain Plug Question
I have a '85 Coupe that has the original radiator, which works fine.
The drain plug is a cheepo plastic one which doesn't work well.
Replacements at places like Autozone, etc. are either similar plastic crap ones or threaded metal ones.
There are no threads for a plug to screw in.
Am I stuck with the plastic, or was there a different kind originally used that I can try to search for?
Any suggestions on what else I can do?
Thanks for any help.
Old Aug 31, 2010 | 02:11 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
http://www.rockauto.com/catalog/raframecatalog.php
I did a quick search for your vehicle and there were a whole lot of options that popped up. You should be able to find it with the information that you have about your vehicle. Good luck.
The official name of that part is a "petcock"... Keep the dirty jokes to a minimum.
Old Sep 20, 2010 | 06:11 PM
krakabash's Avatar
Thanks.
My problem is a leaking Petcock.
My radiator takes the push in type, and I can't figure it out.
When it gets hot, it fails.
I assume because I tighten it too much in an effort to get it not too leak...
vandy
FWD Tech Guides '95-'07
Dec 8, 2020 05:47 AM
Zeke
Feb 18, 2012 12:05 AM
03MonteSS3.8
Jun 25, 2011 11:51 AM
joesumrall
Oct 25, 2007 09:47 PM
montess_24fan
Jul 14, 2007 03:50 AM
