Radiator Drain Plug For 2000 SS
Old Jun 30, 2007 | 11:40 PM
montess_24fan's Avatar
Default Radiator Drain Plug For 2000 SS
Can someone tell me where the damn drain plug is!!!!!
Old Jul 1, 2007 | 09:14 PM
06LT3's Avatar
Default RE: Radiator Drain Plug For 2000 SS
On the radiator,lol.. Actually im not sure on the newer ones. I know on most older years it was on the passengers side on the bottom of the radiator.
Old Jul 1, 2007 | 11:08 PM
Is it just a plug or is there some coolant line along with it because the only thing on the passenger side at the bottom is some kind of line going into the radiator.
Old Jul 2, 2007 | 01:13 AM
06LT3's Avatar
I know sometimes on the bottom cradle that holds the radiator there is a hole with the drain plug underneath that. Let me know. cause im not sure on this.
Old Jul 3, 2007 | 09:29 PM
dad0098's Avatar
On my 04 3800 , it's on the drivers side facing the motor & I believe it's a 18mm socket you can use . It's a plastic nut like plug & there's a hole right below it where the coolant runs out .
Old Jul 14, 2007 | 03:50 AM
kent00SS's Avatar
That is true on my 00 its on the drivers side, id does have tabs to turn off by hand if loose enough, but i know it metric and 18 mm sounds right. you dont actually have to take it outcompletely drains at about halfway unscrewed and drains into the frame where its channeled to a hole in the frame. prolly wont be able to see it by eye, but you can deff feel it
vandy
FWD Tech Guides '95-'07
Dec 8, 2020 05:47 AM
Zeke
Feb 18, 2012 12:05 AM
03MonteSS3.8
Jun 25, 2011 11:51 AM
krakabash
Sep 20, 2010 06:11 PM
joesumrall
Oct 25, 2007 09:47 PM
