dyno tuned 07 monte lt 3.5
Old Sep 20, 2010 | 01:59 PM
Montecarloguy07's Avatar
Default dyno tuned 07 monte lt 3.5
i have decided i want to get the best performance i could out of my little 3.5 v6 so ont thing i am gonna do its get a dyno tune but befor wasting like 400 i would like to see if anyone has done this to a lt yet and what performance did you get out of it
Old Sep 20, 2010 | 02:37 PM
montecarlo01ss's Avatar
honestly your not going to see that much of a gain from it without more extensive mods... dont get me wrong theres always gains to be had with a tune but your basically stock
Old Sep 20, 2010 | 03:57 PM
JaxJim's Avatar
I'm thinking the same thing as montecarlo01ss - there's not much if anything that you could "tune" on that car, unless the shop in question is doing a custom tune on the PCM. If the dyno shop is reprogramming the PCM, and you could see the before and after power curve, that would be cool. I'd hate to spend $400 if it's just a few HP.
Old Sep 20, 2010 | 04:05 PM
usually a dyno is going to do you well if you have larger things like headers, turbo, supercharger, etc, because then its really going to adjust the pcm tuning to help raise the effectiveness of those power adders.
Old Sep 20, 2010 | 05:12 PM
zipper's Avatar
Like everyone is saying, a dyno tune is good AFTER you do a bunch of stuff. When I was NA, I had my Monte dyno tuned twice. The first time, I had a bunch of stuff done (headers, CAI, bolt ons, etc.) and put down 205whp. After the tune, it put down about 210whp. That's not a big gain. The second time that I went when I was NA I put down 218whp (I had added P&P heads and .045" head gaskets) and after the tune I made 222whp. So, each time I did gain all across the power band but in the end, I really only gained a little bit. The nice thing is though is that ZZP is very resonable price wise. I've never payed more than $165 to have them dyno tune my Monte.
If you can find a shop that will dyno tune your Monte for under $200, I say go for it. It's a great experience, and it's also a plus to know what kind of power you start out with.
Old Sep 20, 2010 | 06:25 PM
I agree here, I would much rather pay about double the price of a tuned pcm straight from somewhere like zzp for a dyno tune, its going to benefit you alot more than just a tuned pcm, so if you can find a cheap dyno, that knows what theyre doing, then i would say go for it, but if you plan on doing some bolt ons, i would do those first before the dyno.
Old Sep 21, 2010 | 11:42 AM
I was going to do a dyno and reprogram the pcm .....i am going to get a cai and i have a exhaust system done...and not sure really what else even bolt on or anything you can do to a 07 monte lt besides spend $2000 on a uni turbo or supercharger so i figured every hp counts but i told the guy not for $400 on a 5-10 hp gain no way in hell so i am shopping around a little more
Old Sep 21, 2010 | 12:12 PM
03SS/00GSE/93LX's Avatar
There really aren't many performance options for you. If you have it tuned, I'd want them to:
- Remove all torque management
- Tune your timing tables to run on 93 octane (3-4* of added timing)
- Dial in your MAF table
- Shorten and firm up your shifts
- Raise your shift points by 50-100 RPM
This should make a huge difference in the way the car drives. While you may only gain 5-10 peak horsepower, you'll make power sooner and lower in the gear and it'll feel alot more responsive. Besides a cold air intake and cat-back exhaust, I really don't know what else you could do it- if you want to get serious about performance, and want to stay in a Monte Carlo, I'd look for an LS4 (5.3L) or 3.8L SS and forget about the 3.5L (no offense to anyone, but there really aren't any bolt-on parts to make a 3.5L quick).
Good luck.
Old Sep 21, 2010 | 12:28 PM
you cant also port the stock stuff, other than that theres not much for the 3.5 right now.
2003supersport
Aug 4, 2009 10:25 PM
Nocturnx
Nov 18, 2008 09:24 AM
Aaron_Provost
Apr 30, 2008 10:34 PM
BeachBumMike
Nov 8, 2007 06:32 AM
z34phoenix
Jan 24, 2007 05:06 PM
