Question About Subwoofers in monte
Old May 7, 2012 | 06:27 PM
16With01MonteSS's Avatar
Default Question About Subwoofers in monte
What sounds best both in a out of the car, Facing the subs towards the front of the car or towards the rear.? Anyone have a solid answer let me know!
Old May 7, 2012 | 06:32 PM
Boxman420's Avatar
There are a lot of variables that can give you different results. Personally i used to meter higher subs and port facing back. If you face them forward and seal it off from the trunk then that would be louder.. I have seen either way louder without sealing it off. Its just trial and error. When you put your subs In try it both ways. It only takes a few minutes to move it around
Old May 7, 2012 | 06:56 PM
test it out for yourself and go from there, there's quite a bit of information on the forum about it, but no set in stone way. Flip the box around when you get it and see which works best for you. my bet is facing it towards the trunk though.
Old May 7, 2012 | 07:36 PM
zzapultimate's Avatar
I've found that facing the rear always get more sound. I've heard that when you face the subs towards the front, the sound waves cancel each other out some and actually decrease the loudness.
Old May 9, 2012 | 07:20 AM
I have 2 12s in mine facing the rear of the car they were installed by the people from MTX.
..I have 4000 watts of power...instahled by MTX.
they were at Mickey shores where I bought the system. And they insisted on doing the complete install..since I bought there top of the line stuff. So facing the rear would be the way to go!
Old May 10, 2012 | 08:45 PM
aussiek2000's Avatar
In a truck car, rear port rear sub is generally the loudest.
Old May 10, 2012 | 11:09 PM
2003L67SS's Avatar
i've tried forward and rear facing, rear facing was far louder for me, but you can experiment with it, there are some sweet spots in there, these cars are loud with subs, and now i officially miss my 15" L7's but them things were friggen heavy, i like my car alot more when it's light.
Old May 10, 2012 | 11:14 PM
Milhouse's Avatar
I've never considered what it sounds like outside of my car so that's never been a concern of mine. What type of box are we talking about here? There is no one right answer, it's not that black and white. The type of box you have, where it's located in the trunk, where the port is located, etc., all of these things factor in to which alignment will sound the best. The absolute best setup I've heard in a 6th gen is a 4th order bandpass ported up through the rear deck. Next to that was a ported box, sub/port back, with the box positioned about 6" from the tail lights. If you're planning on metering it, sub/port forward and sealed off generally yields the best results, but you're got to make sure the trunk is completely sealed off so no air pressure gets in there.
igerard
Jun 16, 2012 08:10 AM
lladro
18
Oct 18, 2010 05:08 PM
67smoky
Mar 17, 2010 07:54 PM
couch
Dec 18, 2007 01:41 PM
