Project "Batmobile"
#41
What exactly have you heard negative about the L67? I'm not sure what your refering to exactly. Before making your decision do more and more research into the sway and engine options. Which means you will have to read a couple different w-body forums.
Just a few things to know/remember things you will need for the sway would be engine harness, pcm, bigger radiator, amoung other things. But don't let this stop you. Just something to know.
#42
i heard that the super charger causes the motor to heat up more and cause problems to the inner workings
i didnt believe it but i just wanna be sure it wont,honestly i think a turbo would be worse
i just wanted to know what you all said
and thats what i started todo,is look at the forums
#43
#45
thats what i was thinking it would do,i could always get a racing block when if goes on me when i get it right?
The only reason you'd destroy the bottom end on one of those is if you do something stupid (bad tuning, not enough supporting mods, stuff like that) or have some other part fail that causes severe detonation (fuel system failure causing it to go too lean, sucking something into the intake, etc). These stock blocks are so cheap generally that you can buy 3-4 of them for the price of a race block too, so when someone does screw up or has some odd failure they generally just swap it out for a low mileage stock block again.
#46
sweet,sounds like the 3.8 is my way to go,now there was a post before i was looking at and it said that the 3.8 supercharged comes with a HD tranny? or if not is their a code i could see on the tranny that would show me its a HD when i go to the yard to get a motor
#47
All of the L67's and L32's came with the 4t65E-HD transmission.
There's not much difference from the non-HD though. Primarily a hardened differential is the difference between the two. As far as internal hard parts, they are the same (generally different gearing, but not always).
Otherwise, that transmission was in so many different cars over so many different years that there are a few trans codes for them.
#48
#49
My input on the whole thing, probably won't be liked But I'll offer it anyway...
1.) as stated 15.9 isn't fast and you will begin to realize this as you get more and more into racing, not only that but the more you get into the racing scene, you will want to go faster now, not 10 days from now not a month from now....it sounds like you are just looking to "Build" this car to beat your friends civic, but once that happens, what happens when your friend gets an evo, or something similar, then you will realize it wil be harder to go faster after you sink your money into the car for stated mods.
2.) The 3400 scene for performance parts is lackluster at best...the last thing you want to do is buy a bunch of performance parts new at top dollar, either have the car break, or you get tired of hitting a "glass ceiling" and not being able to go faster, then if you demod the car, you will see you will not be able to sell the parts at all...and certainly not at a good price...3800 and 3800sc parts probably have more of a following and would be easier to sell if that road comes...something to consider.
3.) I hate to break it to you but I doubt the 3400 or even the 3800 scene will grow much from new companies performance wise...I doubt there will be any breakthrough companies making new products...same could probably be said for the LS4..perhaps even more so then the v6 lineup....most performance people and companies have moved onto LS1/LS2/ LS3 and so on engines now that those engines are more available in more affordable RWD cars such as the GTO, Older Vettes, Camaros,G8's etc.
4.) I know what everyone is saying your better off getting a 3800/3800 SC and I agree with them to an extent. Most definitely it will give you the new found power of throwing you back which you crave....But I am not to eager to agree on the whole engine swap thing....it does sound easy on paper, pop engine out, pop new engine in, and boom done...there is a lot more to it then that, and I'm sure it would be easier if your a mechanic, knowledgeable with these type of swaps, and have the neccessary lifts/tools to do so....but honestly, most people aren't and what ussually happens is the swap gets half way done, perhaps even 3/4's and issues start to occur...things don't fit, electrical wires are throwing codes, this that or the other thing occurs...then frustraition starts to build due to the lack of car, waisted money and not getting anything done...eventually the entire project gets sold off for pennies and people start over with something new.
My Take? Save as much as you can, look for a nice 2004 Supercharged Monte, sell or trade in yours....put all your current mods (Neons and what ever else is done) on the new car and there you have gained lotsa HP and have a turnkey car ready to go....and eventually start to mod that to go faster, as stated dollar for dollar you will be going lots faster then a modded 3400.
Oh yeah and in regards to being different....your modding a FWD , Heavy Monte Carlo to go fast.....your already different right there...how many monte LS's do I see in my area....maybe 10 a month...how many SS's do I see? Maybe 1 a month....How many are modded.....0...don't get to much more different then that...
Again my 2 cents, but best of luck with whatever you decide....keep us updated on progress.
Joe
Joe
#50
Unless you're really familiar with doing this engine swap (and the physical engine swap is about 10% of the swap work itself..electrical is a bitch on it) or know someone experienced with this engine swap that is willing to help you do it for free, then you'd be much better off just switching over to an already supercharged car in the first place.
Before I got rid of my 2001 LS, I looked into the price difference of paying someone to do the engine swap vs buying a used 2004 s/c car, and trading in the LS for an SS ended up being a much cheaper option all in all. That is also considering that the SS I got was much lower mileage (30k vs 120k) so the body and suspension was in much better shape, and it also came with all of the other goodies the SS comes with.
Definitely worth looking into since the s/c ss cars are going for under 10k used with low mileage, and if your LS is still in good shape you can unload it for a decent portion of that cost.
there is also an hd conversion kit that is sold to turn the reg tranny to the hd version
