Pretty proud of my Monte :P
Old Oct 22, 2012 | 12:30 AM
Latasha's Avatar
98 Monte Z34 with 173k iv replaced dimmer switch and a water pump that's it
Old Oct 22, 2012 | 04:30 PM
aussiek2000's Avatar
2004 3.4 with 110k. I've replace the battery, water pump, and temp door actuator, under $150 total.
Old Oct 22, 2012 | 05:44 PM
BlackRainSS's Avatar
Thats damn good for a 3.4!
Old Oct 22, 2012 | 05:47 PM
Lorenzo's Avatar
Well i just bought my 2000 SS for 1300 and things im planning to do this week are : Replacing the valve cover gaskets, Replace upper Intake plenum and the lower intake gasket, 2 tie rods, serpetine belt, air/cabin filter and both lower control arms. Car only has about 245 000 kms on it. But engine runs smooth as it can be and passed emissions with really low scores
Old Oct 22, 2012 | 07:23 PM
tps221's Avatar
used fuel pump, brand new ac delco starter, uncle said he burnt out the alternator 3 times, 0 times so far with a brand new sony 205 watt cd player and 800 watt amp powering 2 10's the secondary cat is bad but who needs it has had oil leaks a few times currently the rear main seal but not bad enough to be deemed a worthy job by mechanic gets low around oil change time. and i put in new front rotors only had to be done because it sat so long nice and strong at 164k
2006MONss
Mar 6, 2013 01:14 PM
iMuf
Jan 15, 2013 06:45 AM
Lorenzo
Dec 21, 2012 10:03 AM
montechick
Mar 9, 2011 08:36 PM
kschmidt319
Nov 30, 2008 02:20 PM
