1st Gen ('70-'72): Power steering
Old Jun 29, 2021 | 01:51 AM
Kpcsgasp's Avatar
Default Power steering
Any advice to tone down an overly sensitive power steering.
Old Jun 29, 2021 | 01:25 PM
Glen01SS's Avatar
I assume by "overly sensitive" you mean it takes minimal effort to turn the wheel?
The easiest way to adjust that is to increase the size of the pulley on the pump, if you've got room, to slow down the pump. That's the cheapest because the next option is to change the ratio of the steering box. Possibly a smaller crank pulley could work depending on your set up and would also be cheaper than a new gear box. My Chevelle ratio is just fine so I haven't had to research options. Deferring to anyone who has done it, I'd say try a pump pulley 1 or 3/4 inch larger diameter and see if that feels good. It looks like your car has aftermarket pulleys that might not be original sizes.
If you mean it takes little movement of the steering wheel to change direction, that would be steering gear ratio. I'm not sure if there are options on replacing the Pittman arm to slow the ratio.
Old Jul 1, 2021 | 09:31 AM
What Glen01SS said! also check the tire presuure I had some new tires put on an SUV a few years back and they were way over the usual pressure. once I dropped it to the 32 lbs. that was on the door sticker it was good.
Old Jul 5, 2021 | 12:52 PM
Kpcsgasp's Avatar
Default Power steering issues
[QUOTE=Glen01SS;726015]I assume by "overly sensitive" you mean it takes minimal effort to turn the wheel?
If you mean it takes little movement of the steering wheel to change direction, that would be steering gear ratio. I'm not sure if there are options on replacing the Pittman arm to slow the ratio.[/J
Old Jul 5, 2021 | 12:56 PM
Kpcsgasp's Avatar
while there is no slop in the wheel any correction results in a sort of “sawtooth” effort as my inputs over correct.
JoeDaMan
May 1, 2019 10:42 AM
Zeke
Sep 15, 2016 08:51 AM
03SSChevyFun
Nov 21, 2010 07:12 PM
NRDMonte
Jan 23, 2007 06:45 AM
