6th Gen ('00-'05): Oil filter options
Old Nov 24, 2021 | 10:24 AM
1st-monte-ls's Avatar
Default Oil filter options
Hey all, been awhile since I've been on, I've got a question for y'all. Has anyone found an oversized oil filter for the 3.4 liter montes? I've got an 03 LS that I plan on taking out dirt/rally racing. I know a larger diameter filter probably won't fit, so if anyone knows of a taller than stock filter let me know!
Old Nov 25, 2021 | 07:55 AM
Jeffs02rwdSS's Avatar
A option would be a wix 51036 . It taller and holds a little more oil than the 51040 . Also makes re.moval easier as because of the size.
Old Nov 25, 2021 | 08:46 AM
A option would be a wix 51036 . It taller and holds a little more oil than the 51040 . Also makes removal easier as because of the size.
Nice, you tend to know a lot of obscure information. You the man!!
Old Nov 25, 2021 | 12:44 PM
This works on 2.5 liter ( 2.8 , 3.1, 3.4 engines) (3.3 , 3.8 engine's) 4.3 liter also. As for the V8 small block in truck's they used a big filter in the 2wd truck's and a 51036 in the 4wd. You might be able to put the big filter on the car's, but I've never personally tried this before. This works on most GM vehicle's from the mid 80's through the early 2000's.
Old Nov 25, 2021 | 03:25 PM
Perfect! Thanks Jeff, I've always wondered how much I can trust a wix filter are they good? I usually run the STP extra life oil filters.
Old Nov 25, 2021 | 03:55 PM
Cross reference it to whatever brand you like.I have used them for years, I've never had a issue with any oil filter. Change oil every 3-5000 miles is my suggestion.
Old Nov 26, 2021 | 11:57 AM
Sounds good! I usually change whenever the message center tells me to, but I'm gonna start doing exact 3k changes after this one.
DAVESS2002
16
Aug 27, 2025 04:15 PM
UWAdventurer
15
Feb 14, 2014 05:52 PM
wht02monte
Feb 23, 2010 12:59 PM
rambler1298
Jan 29, 2008 06:11 AM
saluteTOme
Jul 3, 2007 11:40 AM
