how to oil an air filter
Old Feb 23, 2010 | 12:15 PM
Default how to oil an air filter
okay ive had my K&N filter the whole time ive had my car and i finally dicided to clean it (completely filled with bugs, dirt, ect.) and it actually took 2 recharge kits. but my question is how do i know how much oil to use should it be dripping off the filter or just a nice little spray over it, it says to make sure its an even red all over but how the hell can you tell that, the filter is dark red so what so you think?
Old Feb 23, 2010 | 12:24 PM
JAFO's Avatar
YOU DON'T WANT IT DRIPPING OIL!!!! I thought K&N was white when cleaned? At any rate you want just a light coat. I would only spray the incoming side, again lightly. let it set for a while to let the oil leach throughout the filter sort of like painting, it's better to applt another light coat then to put too heavy of a coat on the first time.
Others can/will back me up or correct me in a little bit so be sure to check back.
Old Feb 23, 2010 | 12:31 PM
DO NOT over oil. You will ruin your MAF by doing so.
Here's how I clean my K&N. Buy the recharge kit (cleaner and oil) then you take the filter off, obviously.
Spray the cleaner on the filter until it has a good saturation, let it sit for like 15 minutes, then rinse off with a hose, not high pressure, don't use a hose head attachment, just the gentle stream.
Then put your filter out in the sun for a while, let it air dry. Try not to use a hair dryer or a fan or anything. Just let nature and time do its thing.
Lightly oil it on the outside (dirty side if you have a panel filter) by using some on the pleats and just letting it work its way down. Then let that sit for like 30 minutes, have a look at it and you will see if some areas are darker than others, either means one spot doesn't have enough oil, or the darker area has too much oil. You can use a shop-vac if you put too much oil on it. Really it's not much, you just need to keep the filter oiled so it doesn't rot or go bad.
Old Feb 23, 2010 | 12:35 PM
i cleaned that S.O.B. 6X and it was still red so idk its not conical filter its just a drop in for teh stock air box. and what about the surrounding rubber, should there be a light coat of oil on that too?
Old Feb 23, 2010 | 12:37 PM
Just the filter needs the oil.
What was your procedure for cleaning it 6x? if you followed my directions cleaning it 6x would take about 8 hours!!!
Old Feb 23, 2010 | 12:59 PM
yep took all day cleaning rinsing and letting it dry. 1 day without my car= withdrawls LOL
HIxArsenaL
Jul 25, 2013 09:12 PM
christophe mc france
Aug 25, 2012 02:12 PM
YellowBomb
Jan 20, 2009 09:29 PM
White05LT
Nov 18, 2005 10:03 AM
