Noise when turning?
Old 01-05-2006, 12:21 AM
zoe08's Avatar
Default Noise when turning?
Hello!! I drive a 99 Monte Carlo. Just yesterday my car started making a weird noise when turning left. Can anyone tell me what this might be? Is there a possibility it could be the struts? Thanks!!
Old 01-05-2006, 02:11 PM
Default RE: Noise when turning?
What type of sound? Have you noticed if the steering has gotten tighter? Have you checked the power steering fluid level? I had a saturn and when I turned the wheel it would make a slight noise, I was out of PS fluid.
Old 01-05-2006, 04:57 PM
zoe08's Avatar
Its hard to explain the sound. a scratching, grinding? maybe. Its not the power steering fluid, thats full. And a new belt was put on it not too long ago.
Old 01-06-2006, 11:03 AM
does it only make a noise when tyou turn the wheel all the way or even just slightly to the left? Where does the noise seem to be coming from the tire? under the car? or the steeling wheel?
Old 01-06-2006, 04:02 PM
zoe08's Avatar
It makes a noise even when not turning the wheel all the way. It maybe seems to be coming from under the car or the tire or something. My dad thinks that maybe its a bearing.
Old 01-06-2006, 04:34 PM
Check out this link.
Steering - Front End Clunk When Turning
http://www.alldata.com/tsb/General-M...04D/index.html
Old 01-17-2006, 09:12 PM
Had the same problem with my last project. There might be a chance that the strut bushings (most likely the top, it is always the first to go). If they are like my last car, the entire strut turns with the wheel. It wears out, just like other steering components. What happens is that almost everybody does not replace them with the struts. Common mistake (not saying anything against your abilities, it's just that a lot of people just don't know about this). Have them checked.
Old 01-30-2006, 11:18 PM
i would check the front wheel bearings. if it sounds like a rumble while your driving and it kinda goes away depending on which way you turn then it is def. the wheel bearings.
Old 08-25-2015, 11:03 PM
I have a 2001 Monte Carlo SS Brickyard I also have a strange noise in the front end only when I turn the wheel to the left- slight or all the way,I have new tires, new front wheel bearings, new brakes, and approx.5 year old cvc shaft on left side whats left that it could be ?????
Old 08-25-2015, 11:50 PM
Your describing the typical symptoms of a failing CV axle joint. More often than not the boot will be torn or pulled away out of position. You should see grease flung all about indicating the boot has failed, let the grease escape and the joint died due to lack of lubrication.
NYGiantsfan
10-16-2012 11:05 AM
Franks 03SS
12-30-2011 06:52 PM
ashleymc34
01-22-2010 10:04 AM
dom82
03-29-2009 09:22 AM
Darkness98
04-25-2006 02:02 PM
Quick Reply: Noise when turning?
