Moaning noise when turning wheel???
Old Dec 18, 2009 | 07:03 PM
ashleymc34's Avatar
Default Moaning noise when turning wheel???
Its been real cold up here in NE and lately ive been hearing a moaning type noise when engine is cool and steering wheel is being turned ..
This fall when engine was first started a slight squeaking noise came from the main belt..Car is mint 03 SS with 89000 miles..
Does this mean new or adjustment to i think they call it the serp belt??
Or just wait till it gets warm again in 5 months..lol
Any input appreciated..
Old Dec 21, 2009 | 09:06 PM
ltrain925's Avatar
add fluid to ur power stering pump, mine did same thing, added fluid now quiet as can be
Old Dec 22, 2009 | 07:45 AM
03SS/00GSE/93LX's Avatar
Yep, power steering fluid gets thick and nasty in the cold- some fresh fluid should help.
Old Jan 5, 2010 | 11:06 PM
ashleymc34's Avatar
Default Yep all set!!
Thanks guys above me!! Took out the coolant overflow resevoir to locate pump..fluid was only an inch or less down and there is no leakage on the garage floor ever..BUT just adding that little bit using a long type funnel and mercon fluid and presto !! no more noise..oh and by the way..while running the engine i used to get a squealing noise from serp belt when cold..anyways i took a rag and while engine running let the belt clean itself on the rag in my hand..alot of dirt etc. came off and no noise from belt now either!!
Old Jan 6, 2010 | 08:40 AM
MAMONTE's Avatar
Glad it fixed the problem...But you used Mercon fluid? The power steering in these cars does not take transmission fluid. You should change your power steering fluid now, and use the genuine GM fluid. GM has a "cold climate" power steering fluid that is supposed to work better for cars used in cold temps. The power steering pumps in these cars are finicky enough with the recommended fluid, so you may be asking for problems mixing power steering fluid with Mercon ATF.
Old Jan 9, 2010 | 09:46 PM
ashleymc34's Avatar
Default huh..
1" of mercon will damage pump?? Guess i can try to suck it out and replace what i can..what a bear just to put it in!! lol
Old Jan 9, 2010 | 09:54 PM
mrl390's Avatar
Ive never had any problems with using ATF in the power steering pump. Thats all I run in any vehicle I have ever owned. Thats whats in my MC right now and has been for over 2 years with no problems whatsover.
Old Jan 21, 2010 | 08:57 PM
ashleymc34's Avatar
oh well..sucked it out with a turkey baster..kinda dirty..replaced with power steering fluid..still no problems 2 weeks later..
Also recleaned the serpbelt with a rag with engine running..made everything,i mean ALL funny noises stop..hey i should dig up billy mays and sell a "magic serp belt cleaning rag" haha
Old Jan 22, 2010 | 10:04 AM
too soon
zoe08
Aug 25, 2015 11:50 PM
Franks 03SS
Dec 30, 2011 06:52 PM
pinky
Aug 12, 2010 11:46 AM
dom82
Mar 29, 2009 09:22 AM
Darkness98
Apr 25, 2006 02:02 PM
