Need a Really Quick Answer
Old Aug 27, 2009 | 09:53 AM
montejass's Avatar
Originally Posted by trewyn15
okay heres what i wanna do, i wanna gut the stock air box, but im not sure on a way to do this efficiently, any ideas?
I posted a how to on this a long time ago that may still be in the how to section, but what you want to do if you decide to gut it is to pull the air box from the car, if you look at the filter (hopefully it is dirty and it will show you very clearly just how much of your filter is being used, my total space used was about the size of a baseball looking at the collected dirt on the filter) I removed the cylinder that feeds air to the filter area and cut away the solid parts between the two pieces that mesh together against the filter. You will want to take care that you don't remove too much plastic and a Rotozip worked best for me to make my cuts. If need be I will pull my box apart one weekend and take pictures for you.
Old Aug 27, 2009 | 09:56 AM
montejass's Avatar
Originally Posted by chibiblacksheep
Bungee is a temporary until he gets his PCM tray :P
Not knocking you too hard on the bungee it just brings up some nightmares I have seen with Bungee Cords.
There was also a PCM tray for a blazer rather cheap that can be had at the dealer that worked well. I'll see if I still have the part number..
Old Aug 27, 2009 | 09:59 AM
what would i bungee it to tho? lol
Old Aug 27, 2009 | 10:00 AM
can i temporarily go without a box whatsoever then put it back later?
Old Aug 27, 2009 | 10:10 AM
montejass's Avatar
By all means, a bungee will probably hold it and you are free to use what ever you want.
I am just not a big fan of rigging things and would rather spend the time, energy and effort to make it look good and have it hold up over time.
Old Aug 27, 2009 | 10:13 AM
the stock box does this.
One is gathers air from behind the headlight, and brings it into its container where it's filtered and sent through the tube to your engine.
It also holds the PCM at the bottom. This is a very important part of the car because it tells your car how to perform. PCM stands for Powertrain Control Module. Right there it tells you that it is the controller of all things for your Powertrain. Very important thing.
When people want more air flow, they realize that a cone filter can grab more air to bring in. When that air is colder it works better because it's denser. That's the importance of a box or heat shield.
When you take the stock airbox out, you are stuck with a PCM that has no where to sit, that's why you have to find something called a PCM tray to bolt into your car, and then your PCM will screw onto that so that nothing happens to it.
https://www.zzperformance.com/grand_...cts1.php?id=91
There is an example of one such tray.
Old Aug 27, 2009 | 11:04 AM
okay heres what i did, i think it would be similar to a pcm tray let me know what you think.
and with those trays, which one would you go with? is the cheaper one still gonna be good? thanks
pics are taking a while but which one of the pcm trays will work better and will it be good with a monte carlo or will i have to drill alot of holes? sorry im not very experienced with montes but you guys are tons of help
Old Aug 27, 2009 | 11:11 AM
Honestly I'm not sure how those PCM trays work, because my K&N kit came with a heat shield / pcm tray.
Neither required drilling, just using already placed holes.
Old Aug 27, 2009 | 11:13 AM
Old Aug 27, 2009 | 11:14 AM
so in that pic the intake is secure in there but the pcm is still there, which is pretty much what i think a pcm tray does, so it should be okay?
