Need a Really Quick Answer
Old Aug 27, 2009 | 11:19 AM
whoa there.
That is a HORRIBLE idea for an intake set-up. Yes the PCM is fine, but all that is going to do is suck in the hot HOT air that your engine makes and nothing of the cooler air that would be coming in through the headlight / fenderwall.
When you are submersing a filter into that much heat, you are actually going to rob your car of power. It may sound nice, but it's putting a damper on performance much more than the stock air box was.
Old Aug 27, 2009 | 11:29 AM
wait, but theres the hole in the headlight where its still coming in directly at the intake, so until i can get something to block off the engine heat i think it is still a good solution, i went and drove around a bit and didnt notice any difference from beginning of drive to end.
do you know what i mean tho, where the hole in the stock air box is from the headlight, thats coming in right at the cone, so it will be getting both types of air, so it will equal out for now until i get a new box or find something new to work with
Old Aug 27, 2009 | 11:56 AM
take a PVC pipe, and move your cone into your fender. You seem to have the room to do that easily.
And I see where you think the hole would give it fresh air, but honestly, look at the size of the hole in comparison to the amount of space around the filter. Once any outside air even hits that engine compartment it will warm right up with it. That is going to give you 0% cold air until you fix it.
And you won't be noticing any differences, because we are talking a loss of a couple HP, but it's there. Especially if you had a way to monitor your air intake temps you would see how hot it really is. Running that hot air into your engine is going to force your engine to pull in more air which means more fuel. Where as if you were pulling in cold air, it would be denser and not require as much fuel. It's all about the air-fuel ratio.
Old Aug 27, 2009 | 12:31 PM
alright thanks, look at my old filter tho, i think it would be somewhat even now, =p maybe not still but you know what i mean haha
Old Aug 27, 2009 | 12:32 PM
MAMONTE's Avatar
Yea, Everything Chibiblacksheep said is soooooooo correct. I see your points, but it just does not work that way. Like Chibi said, as soon as any bit of cool air enters, it turns hot instantly because nothing is blocking the hot air from the cool air. I am sure you air temp are hotter now than they were stock. This is why even manufactures got away from just sticking an airfilter at the end of the throttle body (or carburertor in the older days)...you really need to get an air box, or heat shield or some sort ASAP.
Old Aug 27, 2009 | 12:33 PM
MAMONTE's Avatar
Damn.....well, at least you have a clean airfilter now...LOL! Just work on getting that box or heatshield and you will be good to go!
Old Aug 27, 2009 | 12:35 PM
lol it was pretty sick taking it out, any ideas of where i can get just a heat shield? or how to make one?
Old Aug 27, 2009 | 12:38 PM
I can't recommend just putting your filter into the fenderwall and calling it a day enough.
they are called fenderwall intakes or FWI, search around for how people did those.
Old Aug 27, 2009 | 12:45 PM
Old Aug 27, 2009 | 01:06 PM
In the fenderwell it would.
Exposed in your engine bay like it currently sits... no
