6th Gen ('00-'05): Need a favor
Old Feb 6, 2013 | 06:23 PM
PacerSS's Avatar
Default Need a favor
I'm trying to slowly refresh this beast and replace parts it never had since I've owned it. With that being said can someone check under their hood at the top air baffle between the radiator and bumper(#7 on the diagram) and tell me how many fasteners#10) there are on it? Also tell me how the two #8s attach, and how many #9s I need to make it work?
Old Feb 6, 2013 | 06:48 PM
#10 = 1 , #9 = 2 , # 8 I looked at mine and I can't see that ??? Sorry.. Mine is an 2005
Old Feb 6, 2013 | 07:43 PM
I don't see part #8 on my 2004 either. Do you know what it's supposed to be?
Old Feb 6, 2013 | 07:54 PM
PacerSS's Avatar
#8 is supposed to be a piece that goes to the right and left side of it I'm guessing below. I don't have anything there so I'm not quite sure.
So the consensus is that there's 1 fastener(10) and 2 retainers(9)? From the diagram it looks as if the retainers clip on to the #8's on both sides what do they clip on to your vehicles?
Old Feb 7, 2013 | 07:11 AM
03SSLE's Avatar
Yes, 1 #10 and 2 #9 but I think they consolidated parts in later years because all 3 fasteners on my '03 are identical. They pass through holes in the plastic air baffle (#7) and clip into holes in the radiator support. I think #8 is a piece of pliable rubber that is located directly under the hood latch mechanism...or at least that is the only thing I can see on mine that remotely resembles it. My guess would be it is there to prevent turbulence around the hood bracket and keep the air flow straight as it enters the radiator.
Old Feb 7, 2013 | 05:39 PM
PacerSS's Avatar
Thanks from the looks of the holes I figured they were all the same.
I found out where the two #8s are, if you look where your ambient temp sensor is underneath your pass headlight. You will see it held on by two snap in button style retainers. Naturally I am missing the driver's side one but the retainers are still in there....go figure lol
rj
Mar 28, 2010 10:52 PM
thumpingetocar06
Dec 16, 2009 05:15 PM
3tErNaL
Oct 4, 2009 12:44 AM
scc24540
Dec 13, 2008 11:29 AM
Nebraska2000ES
Dec 28, 2005 03:54 PM
