Monte Headlamp Problem...
Hey guys!
First post here. I've been a long time monte carlo owner. I've owned a 77 in high school, an 87LS, 88 SS & my current 2002 Monte Carlo LS with only 45 Thousand miles on it.
Moisture got into the headlamp connector and rusted away the male high-beam prong coming off the headlamp wiring harness. I have not been able to find the part anywhere and it will be sometime before I can get to a salvage yard.
I've got brand new headlamps so the female connectors are fine but untill I find either the headlamp harness (or even splicing in a new connector) I am missing my driver side hi-beam.
Does anyone know where I can get this?
It is part 8 in this diagram:
Thanks,
Rick
Thanks,
Rick
If you need just the connector that plugs into the bulb you can get it at Autozone:
Duralast/Headlight Connector (365) | 2002 Chevrolet Monte Carlo 6 Cylinders K 3.8L SFI OHV | AutoZone.com_
If you're unable to get to a junk yard, maybe see if someone can go for you. A salvage yard is your best bet. Going to the dealership is paying an ungodly amount of money for nothing.
Unless you find someone parting out a wrecked Monte on the internet somewhere.
Thanks for the Junkyard Advice.
Does anyone know how I can find out the part #? The only Diagraims I can find are at a GM Parts Retailer and the part # is listed as unknown.
It's ironic, I restored a 1968 Dodge SuperBee and every part I needed I was able to locate in a matter of days. This silly wiring harness continues to elude me.
Thanks
rich
Thanks
rich
SGSCharger
12-15-2012 08:49 PM
