Moaning sound when turning wheel
![Question](https://montecarloforum.com/forum/images/icons/icon5.gif)
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
It sounds like your power steering is low on fluid. Just go pick some power steering fluid up, top it off and then see if it gets low again. Then you'll know if your power steering pump is going bad or not. I would wait to take it to a shop.
yep power steering. probly low on fluid. but where has the fluid gone? id fill it up and look for the leak. it will be pressured out of the leak spot when you turn the wheel. so have someone in the car turning the wheel left to right(while running) and someone else looking for the drip. if there is only yourself you can do both it will just take alittle longer goning back and forth from turning to looking.
you can still drive it if there is a leak just fill ity back up when you start hearing the noise again. unless the fluid drops out fast. youll be good doing that until you find the leak and, or have to relpace the pump. you have to replace the pump if the pump is full of fluid but still making the noise.
I checked the fluid--it is coal black
. It is full also. Now what
? I will be taking it to the garage on Monday--he's on vacation this week. ugh
I drove it today to the garage and it sounds like the engine making a moan if I even touch to sterring wheel to the right let alone actually make a turn. Nothing else seems amiss but that sound and a little roughness in the steering when I sit in one place and turn the wheel to the right. The motor sounds like a single engine Cessna going over head at 3 am. Ever hear something like that? thanks again
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
