Mass air flow problems
Old Aug 10, 2018 | 05:20 PM
So what would be unusual at idle.. I watched mine at idle and it jumps between 0 and 0.4. Is that normal? Also, while driving it seems to fluctuate while I do my best to keep the gas pedal in the same exact position.
Old Aug 11, 2018 | 06:14 AM
That sounds reasonable to me. And while driving the fluctuations could be the torque converter locking / unlocking.
Old Aug 16, 2018 | 02:32 PM
coolhand's Avatar
Originally Posted by llojak2004
Hello, I am having problems with my 2001 Monte SS. I had a code for a bad mass air flow sensor so I bought a Walker unit and it lasted 2 weeks then went bad so I bought a new one from autozone it is a Valuecraft unit and it cost $129 with a lifetime warranty and it lasted 3 weeks and went bad. I disconnected it and it runs but poor gas mileage. I have had it at a dealer and said the throttle body is bad which I cleaned it and put a new fuel filter and throttle pos. Sensor on and same result. Help??
My 02 SS had the same problem. I tried 3 different MAF sensors and they all still threw a code. I wound up buying a used one off ebay, the same GM part number as the original and it's been working fine. The aftermarket sensors never seem to work right for some reason.
Old Aug 16, 2018 | 02:53 PM
llojak2004's Avatar
Default M
Makes sense
TMoney
22
Mar 18, 2017 10:19 PM
Chiefeng
Aug 14, 2014 07:19 PM
bigjohnson9859
Mar 21, 2012 03:52 PM
White05LT
May 20, 2007 11:39 AM
