6th Gen ('00-'05): List of issues on my Salvaged '02
Old Aug 11, 2013 | 08:44 PM
Monroe's Avatar
Monte of the Month -- December 2013
Originally Posted by Metalsmith
Mine started stalling and got worse till you had to start by blipping the throttle and feathering the gas to keep running, cat glowed red hot...we swapped out everything and asked a guy to use his Tech II scanner ... when we started it up , he said shut it off.... pulled all the wires and gas lines up from behind the TB.... there was a big melted hole where the flex tube from the egr, goes into the UIM.... egr was stuck open and the hot gas from the exhaust caused a melt down.... ECU threw every find of code there was as it could not cope. Glad it did not melt into the TB water passage, as I have heard that cause a lot of grief... He stuffed a wad of duct tape in the hole and 3 patches on top and it ran like new back to the shop...but would not think that would last for long.... I replaced EGR and UIM.... replaced LIM gaskets while it was down ... runs great !!!
Im not very familiar with EGR or UIM. Have any pics of the hole/location of hole?
Old Aug 12, 2013 | 08:06 AM
Metalsmith's Avatar
If you look behind the throttle body, you will see the EGR( exhaust gas recirculation)..... it has a stainless flex tube running out the bottom and it goes under where the TB bolts to the UIM ( upper intake manifold) Here is a pic of the egr tube and where it comes up under the lower manifold.
This is a good link to the fix... Change Upper Intake Manifold & Lower Intake Manifold gaskets : Engine
Nintendo_King
Dec 6, 2014 12:20 AM
BlackRainSS
Jul 24, 2012 10:23 PM
01montesf
Jul 7, 2010 06:59 PM
BeachBumMike
Dec 7, 2007 12:44 PM
01pacecar
Mar 8, 2006 05:03 PM
