leaking sunroof and pillar
Old Sep 29, 2010 | 05:14 PM
nighthawk626's Avatar
Default leaking sunroof and pillar
guys im really ticked off. lately its been raining like crazy here in sc and im thinking thank God i dont have my ttops firebird anymore. then yesterday i walk in my car and as soon as i hit the gas i felt water pour on me from the sunroof area and the headliner was wet. today on my way to work, i noticed a very wetspot where my pillar connects to the roof. i feel like crying and im already thinking about doing a trade in. Intimidator edition or not this is unacceptable. my friends 97 honda sunroof doesnts have a single leak wit its 210k miles smh
Old Sep 29, 2010 | 06:35 PM
is the drain hole plugged?
Old Sep 30, 2010 | 06:34 PM
on the passenger side, and i just realized my whole passenger side carpet is drenched. FML
Old Sep 30, 2010 | 06:44 PM
I was thinking maybe the drain hole being plugged up too. But when you said the carpet is wet, that blows my theory. Almost sounds like a combination of problems. I know if the cabin filter box isn't closed and sealed properly, your carpet will get soaked.
Old Apr 27, 2012 | 03:56 PM
montecarlolady's Avatar
Smile Sunroof drain hose clogged... or kinked?
My drain also backed up on one side for the last few years. I read a TSB somewhere that the lower part of the hose may be flattened by the kick plate insulation. So I went into the hole below the emergency brake with a small camera, and indeed found it so. Even air would not flow through.
The hole is too small to reach in for a fix, but the hose end grommet pulls out if you give some slack.
First, undo the door garnish then sunvisor/headliner. Detach hose from sunroof, feed it partially back into the A-pillar. The kink may be stuck together, but a squeeze should open it again. Then pop the grommet back in and reattach hose to the sunroof nipple, etc.
Last edited by montecarlolady; Apr 27, 2012 at 04:08 PM. Reason: image links broken
Old Apr 27, 2012 | 06:49 PM
BlackRainSS's Avatar
Great info to add but the threads pretty old.
ladyvyxen
Jan 14, 2013 08:28 AM
bigmichaelcool
Oct 15, 2012 06:02 PM
Jordanshedd5
Feb 14, 2011 01:24 PM
ceaser
Oct 13, 2010 11:35 PM
ckerdflag
Jun 1, 2007 09:59 AM
