KR and choke?
Old Apr 30, 2014 | 11:06 PM
NYGiantsfan's Avatar
Default KR and choke?
so i recently had to change 2 coils picked up some a set used from a junk yard.
it was going thru some bad shifting, misfires and hesitation not to mention my kr meter shoots upto 12 sometimes.
i changed the 2 coild that need to go and now have kr issues. after 3rd gear around 3-4k rpm i hear some kind of sparking or knocking and even if my foot is still on the pedal the car feels like its off for a second
i have the zzp super charge kit installed never had any kr issues till now.
what im wondering if its still from the coils or not, what i find unusal is when im on the highway, and try to go faster the engine feels like it stops for a sec kr meter shoots up i hear a lil knocking or sparking like when u unplug a wire from the coil.
i run 93 octane, engine feels weird still like loss of power and sluggish
thanks
Old May 1, 2014 | 05:38 AM
Sure it's the coils and not the plugs or wires?
Old May 1, 2014 | 01:31 PM
turbo monte's Avatar
You need to get off the throttle when you see that kind of kr! Kr will turn your engine into a ticking time bomb very quickly. I suggest doing a compression and a leak down test on the engine to make sure the engine is still ok and you haven't chipped a piston etc. If the engine is good you need to data log to figure out what is happening to cause the kr.
I would change the other coil and change plugs and wires. I don't think it's a ignition issue but doesn't hurt to do a tune up. I'm thinking more along the lines of a fuel issue though imo
Old May 3, 2014 | 01:14 AM
Yea changing the coils got rid of my misfires, I'll take off the 3 fron plugs and check em out, I just tuned it up like 11 months ago with the install of the supercharged kit tho. I no i do have a fuel sender problem gauge goes from f to e every ten seconds , Also mechanic told me of a fuel pressure issue causing it to take long to start. And yes i did the fpr wasted 60$ :@ I dno i guess I'll check on the plugs in the am see what condition there in. If not I'm gna have to dish out for this ridiculous fuel pump job.
It sux i have to drive real easy on highways going to and from work
Wat y'all think?
Old May 3, 2014 | 01:36 AM
nitehawkjcb's Avatar
Wat y'all think?
Check your fuel pressure... 12* of KR is horrible... Keep your foot out of it, or it's gonna blow up.
And fuel pumps are easy to do on later model W bodys... There's an access hatch in the trunk. Make sure you look at your wires on the sending unit also.
That being said, it never hurts to have a spare MAF laying around.
baNe
Jan 8, 2015 07:10 PM
73monte
Apr 23, 2012 07:42 AM
Kracktheskye
Mar 23, 2011 04:45 PM
dirty mech
Jul 24, 2010 01:17 AM
loudNproudSS
Apr 25, 2008 10:27 AM
