7th Gen ('06-'07): Key fob issue
I'm looking for a little help here. My key fob has gotten to where it only works to lock/unlock the car right after it's been shut off. If it's been off for more than a few minutes it won't work at all. I tried replacing the battery and relearning it to the car.
Thanks,
Jonathan
Thanks,
Jonathan
It's probably time to replace it. I know they're not supposed to "go bad," but mine stopped working entirely, even with a fresh battery. I know it's not the receiver in the car, because my wife's fob works just fine.
I see this is an older thread but I am having issues on my granddaughters 02 Monte Carlo keyless entry. I have found the receiver module under the upper front dash board was all distorted from the Texas heat, I believe it has failed and need a new one. But the part 15042696 is discontinued, do you all know anyone making replacement parts?
Thanks
Thanks
Thanks
Thanks
I’ll have to go to the car and pull it to check the part number and then you can shoot me an offer. I can ship it COD and an email money transfer should work fine I’d think. I’ll even send the fobs that I have for that car if you’d like.
I have a 2000 Monte. My FOBs no longer lock the doors. Only unlock , and open the trunk. The dealer replaced the batteries. Didn't fix the problem. They surmized it was an electrical problem, and had the potential to be an expensive fix. Just living with it now
