FOB Help Please!
Old Sep 2, 2011 | 02:34 PM
tj4ndirish's Avatar
Default FOB Help Please!
Ok, so when I bought my '05 Monte, it was a demo, I only received one FOB. I ordered a second one on ebay. I programmed the new one and then for some reason, the original one stopped working. So, for the last 6 years, I've used the one I ordered.
Last week, it stopped working, safe bet the battery went dead, right? I opened up the fob and went to take the battery out and the bracket that holds it in came loose.
So, I figured no big deal, I'd get my original fob and reprogram it and I'd be good to go.
I went through the programming steps and heard the beep that signals that it's been programmed. Well, when I went to try it, it didn't work.
Anyone have thoughts? If I try to solder the bracket back on will it work or am I gonna be stuck buying a new fob?
Thanks for any input.
Old Sep 2, 2011 | 02:42 PM
I try to fix it if you can. If not you can then buy a new one.
Old Sep 2, 2011 | 02:44 PM
tj4ndirish's Avatar
Thanks for the input Lou.
I guess my main question should have been why wouldn't the original fob work??? I'll try some soldering tonight.
Old Sep 2, 2011 | 05:04 PM
FYI - When programming a fob, you program the new fob AND re-program all your other fobs (up to 4 fobs). The moment you successfully program one new fob, it erases all previous fobs in memory.
Old Sep 2, 2011 | 05:21 PM
zipper's Avatar
I never knew that. Hopefully that's what fixes tj4ndirish's problem.
Old Sep 2, 2011 | 06:29 PM
Hmm that is interesting & yeah id try to fix the one first
Old Sep 3, 2011 | 10:45 AM
At least on the 6th gen Montes. That's why the instructions tell you to have ALL fobs available when you do fob programming. I'm trying to find a way to erase all fobs in memory without adding a fob, but that's a different problem and I think the answer is "can't be done".
joscle24
Apr 28, 2014 10:15 PM
MonteLSV6
Mar 4, 2013 08:57 PM
Great White North
Mar 31, 2006 12:52 PM
ralphtrent
Dec 24, 2005 01:01 PM
03SSdriver
Sep 16, 2005 10:43 AM
