Ignition Cylinder Bezel Availability?
Old Jul 18, 2009 | 08:45 PM
options13's Avatar
Default Ignition Cylinder Bezel Availability?
Hi, Has anyone replaced the bezel around the ignition switch? Mines an 04, in the dash. Wondering what the availability is & maybe approx cost?
Thanks!
Old Jul 18, 2009 | 08:51 PM
mrl390's Avatar
Are you talking about the instrument panel bezel that goes around the radio, gauges, ignition cylinder, ect? GM parts direct has it listed for $215.84.
Old Jul 18, 2009 | 08:52 PM
saigashooter's Avatar
I think he is talking about the rubber boot that surrounds the ignition on the 2000-2005 models.
Good luck finding an after market one. Your best bet is the stealership, or check classifieds for someone parting out their crashed monte.
Old Jul 18, 2009 | 09:11 PM
MonteDriver's Avatar
or look in junk yards there may be a few wrecked ones or maybe someone you know has been rear ended and would take it off their car and send it to you.
Old Jul 19, 2009 | 10:41 AM
options13's Avatar
I'm talking about the round piece that says off, start, acc, run, about 3" in diameter. I'm going to call my friend at the pontiac dealer who treats my right. I always buy my oem GM parts through him. Hopefully it's not one of those parts where you have to buy the whole dash to get. I wouldn't think so. It's actually plastic, not rubber, so the tabs broke off.
Old Jul 19, 2009 | 12:54 PM
I hope I'm wrong, but it may be part of the ignition cylinder. Which is pretty expensive for just the piece you need. Would you be able to simply glue yours back on?
Old Jul 20, 2009 | 12:16 PM
options13's Avatar
Default Got it!
It's still available, my cost is $3.80 through the GM dealer. I think it retails for about $8-10.
Old Oct 27, 2011 | 07:02 PM
tr2v's Avatar
Exclamation
I hope you'll see this! I'm looking for the same thing. The snaps fell off of mine. Can you tell me what it's called or send me a link or anything? I tried searching for 2004 monte carlo ignition switch surround, 2004 monte carlo ignition switch ring, and 2004 monte carlo ignition switch bezel, but found nothing.
Any help is appreciated!
Old Oct 27, 2011 | 08:56 PM
his last activity was 2 years and almost 3 months ago let me look for you tho.
I can't seem to find it, but you could take this diagram in and show them where it is. It's in number 5
Old Oct 28, 2011 | 05:52 AM
This is probably a bad idea to continue a dead thread, but hit up ZSPOT. You can find him here:
Forums - NAIOA
Chibi and I both support him as noted in the below thread (which explains what he does):
https://montecarloforum.com/forum/pr...m-parts-28933/
