6th Gen ('00-'05): Idle and gauge cluster issue.
Old Aug 19, 2019 | 06:30 PM
04montecarlo-ss's Avatar
Default Idle and gauge cluster issue.
Hello everyone. We just acquired a 2004 monte carlo ss with 57k miles, it was my wife's grand mothers and she got a new car because the steering rack needs to be replaced and it has a battery drain issue.
It hadn't been started for 8 months or so and they gave it to us so I went and picked it up. I started messing with it today and I put a brand new battery in it. It starts up but if I don't give it gas it will die but it runs great doesn't seem to surge or anything when I'm on the gas going down the road. I'm gonna put 5 gallons of gas in it with some injector cleaner and see if that helps. When I was driving it, the rpm gauge and speedo would go to 0 then back to the speed I was going and the battery light would flash along with the traction control and abs. Any ideas where I should start?
Seems like it might be a ground or gauge cluster but the idle seems like something else. Any help would be greatly appreciated.
-Joe
Old Aug 20, 2019 | 07:30 AM
Sounds like two different issues as you assume. If you put a new battery in, it sounds like a ground.
The "needing to keep on the gas" thing could be the IAC valve in the throttle body or possibly the MAF.. Could be a plugged fuel filter or cat..
Hope something in there helps..
04montecarlo-ss
Aug 25, 2019 05:44 PM
John Baca
Jun 1, 2013 04:43 PM
04chevyboy
Apr 22, 2012 06:43 PM
2005 SC SS
Feb 11, 2011 09:07 PM
Visual7
Aug 29, 2006 08:50 PM
