i need 6th gen dash measurements
i need the width (door to door) height ( top to botom) and depth (windshield to face) aproximate dementions are fine, as long as it's close,
I'll get the tape measure out and get some measurements in the morning. It's 11 pm here in the east. Too dark and scarey outside. lol.
You looking for the measurements of the entire dash section inserted into the car, including the center console that goes down from the dash and extends between the front seats?
Here's a good generalization, I'm obviously not near my Monte right now.
Wheelbase
2000–05: 110.5 in (2807 mm)
2006–07: 110.5 in (2807 mm)
Length
2000–05: 197.9 in (5027 mm)
2006–07: 196.7 in (4996 mm)
Width
2000–05: 72.7 in (1847 mm)
2006–07: 72.9 in (1852 mm)
Height
2000–05: 55.2 in (1402 mm)
2006–07: 55.8 in (1417 mm)
Wheelbase
Length
Width
Height
I measured 56" across the front of the dash from door panel to door panel at the level of the air vents. Not including the removable side panels covering the fuse blocks. Those panels are less than an inch each.
I also measured 56" across the top of the dash where it touches the windshield. However it indents a bit at the A pillar. I forgot to measure between the A pillars.
The height of the dash is a very approximate 16-17 inches on the passenger side. I had to eyeball it because of the curve of the dash.
Hope this helps.
Hope this helps.
