i need 6th gen dash measurements
Old Aug 4, 2010 | 07:39 PM
Budsjlm's Avatar
Default i need 6th gen dash measurements
i need the width (door to door) height ( top to botom) and depth (windshield to face) aproximate dementions are fine, as long as it's close,
Old Aug 5, 2010 | 08:53 PM
Budsjlm's Avatar
Bump!!! come on 10 mins out side with a tape messure i know there's tons of 6th genners on here!!!
Old Aug 5, 2010 | 10:14 PM
I'll get the tape measure out and get some measurements in the morning. It's 11 pm here in the east. Too dark and scarey outside. lol.
You looking for the measurements of the entire dash section inserted into the car, including the center console that goes down from the dash and extends between the front seats?
Old Aug 5, 2010 | 10:21 PM
Budsjlm's Avatar
i'm not too worried about the center console yet but if you want to take them too cool, thanks Taz,
Old Aug 5, 2010 | 10:23 PM
sure thing
Old Aug 6, 2010 | 06:35 AM
LOL I would do this for you, but Id probably come out with some off the wall extremely larger than life number..
Old Aug 6, 2010 | 08:21 AM
Here's a good generalization, I'm obviously not near my Monte right now.
Wheelbase
2000–05: 110.5 in (2807 mm)
2006–07: 110.5 in (2807 mm)
Length
2000–05: 197.9 in (5027 mm)
2006–07: 196.7 in (4996 mm)
Width
2000–05: 72.7 in (1847 mm)
2006–07: 72.9 in (1852 mm)
Height
2000–05: 55.2 in (1402 mm)
2006–07: 55.8 in (1417 mm)
Old Aug 6, 2010 | 04:45 PM
Budsjlm's Avatar
nice try mike but i'm looking for Dash mesurements!
Old Aug 6, 2010 | 05:05 PM
I measured 56" across the front of the dash from door panel to door panel at the level of the air vents. Not including the removable side panels covering the fuse blocks. Those panels are less than an inch each.
I also measured 56" across the top of the dash where it touches the windshield. However it indents a bit at the A pillar. I forgot to measure between the A pillars.
The height of the dash is a very approximate 16-17 inches on the passenger side. I had to eyeball it because of the curve of the dash.
Hope this helps.
Old Aug 6, 2010 | 07:22 PM
Budsjlm's Avatar
Thank you verry much taz now onto my search!!!
