HOW DO YOU INSTALL THE MESH GRILLS
Old May 22, 2008 | 06:46 PM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
Default HOW DO YOU INSTALL THE MESH GRILLS
HEY GUYS, HOW DO YOU INSTALL THE MESH GRILLS ON THE FRONT AND LOWER PART OF THE BUMPER?
Old May 22, 2008 | 07:48 PM
big_mecho13's Avatar
Default RE: HOW DO YOU INSTALL THE MESH GRILLS
What grill did you buy?
I only did the grill as you can see. I had to take off the grill. pretty easy thing to do.
If you are facing the engine bay.look for plastic round tabs the closest ones to youpull them out remove or lift the plastic get your hand under there and get the grill to snap off i think it is held in place by the chrome/plastic trim piece around it. That is the best I can remember I did it almost a year ago but I can look and maybe take pics over the weekend if you still have problems.
Old May 22, 2008 | 07:52 PM
cool I just bought the mesh from the hardware store and thought i paint it black and cut it to size and I needed to know how it was held up. When I get to doing this if i run into any problems i will post. Thanks for the tips
Old May 22, 2008 | 08:16 PM
Gotcha Mine is held in place by wire. Basiclly you take the front plastic grill and then place the mesh ontop of it then use wire close to the color of your mesh and you loop it through the mesh and plastic frill and then tighten on the backside if you do it right you can even see the wire you are using to hold it in place. I only used it in the corners.
Old May 22, 2008 | 09:40 PM
sweet, sounds good, thank you
Pure2sin
May 23, 2011 09:26 PM
nighthawk626
Mar 30, 2011 09:18 PM
Beautikill.2000monte
Sep 3, 2010 02:59 AM
mavrickf1613
May 4, 2008 07:55 PM
98monte
Mar 13, 2008 01:03 AM
