!!!!HELP!!!! My KEY is STUCK IN IGNITION :'(
Old Jun 20, 2011 | 05:52 PM
MsFiasco's Avatar
Default !!!!HELP!!!! My KEY is STUCK IN IGNITION :'(
I have a 2006 SS....and my key will NOT come out of the ignition. The gear shift is fine though. When I had a 2006 LT last year and it did that, it was a case of the wiring harness under the shift gear. B/C the shifter was stuck in park. But NOW i can easily shift gears, but I CANT GET MY KEY OUT!!! . Any ideas?? HELP!!!!
Old Jun 20, 2011 | 06:21 PM
Mine does this sometimes if I don't push the shifter forward all the way. Just a thought.
Old Jun 20, 2011 | 10:03 PM
bearbear3_4's Avatar
I've had the same thing happen, I just start the car and move back then forward a little more then I was.
Old Jun 21, 2011 | 08:28 AM
I had a '98 Grand Prix "hold the key" when the battery was near dead or had a poor connection (you'd try to start the car, it would not start and lights would go out and the key was stuck). Once you got power flowing again, the key came out with no problem.
Old Jun 21, 2011 | 08:47 AM
03Monte's Avatar
i agree with this comment...it's either that or the ignition cylinder went out...
Old Jun 21, 2011 | 08:50 AM
mistiksky's Avatar
if its not that try some silicon lub
Old Jun 21, 2011 | 09:15 AM
TheMonteMan's Avatar
never had this happen. i did have the key get stuck when the battery died, and i put the car in gear to move it. the car starts and runs though right?
Old Jun 21, 2011 | 10:04 AM
mistiksky, graphite powder is better for locks than silicone because it does not collect dirt and gum up.
Old Jun 21, 2011 | 12:38 PM
Start the car back up... straighten the wheel out and shut it off then pull the key out
Old Jun 22, 2011 | 02:15 AM
MsFiasco's Avatar
Thanks guys for ALLLll ur input! Turned out there was a short in a wire in the ignition. Cost me a good 150 bucks . but my Monte is up and running again (^_^)!!!
*sidenote*
I PAST MY 10 DAY PERIOD....THAT MEANS.............I GET TO UPLOAD PICS!!! WOOOO HOOOOOOOOOO......... #staytuned....
