5th Gen ('95-'99): Headlights
Old Mar 4, 2012 | 05:51 PM
Cover the yellow lights, brilliant idea lol. Final verdict on the Silverstar ultras. Tested them in my dads GMC envoy and they are considerably brighter which leads me to the conclusion that the monte carlo lens is just of bad design. I'm back to square one with my original bulbs and i now need a new plan for lights. My guess is to go HID, recccomendations?
Old Mar 4, 2012 | 05:56 PM
zzapultimate's Avatar
ddmtuning.com 35 watt hands down.
The ebay ones aren't too bad either.
Old Mar 4, 2012 | 08:41 PM
Now would i need highs and lows or just replace my low beam lights? (hate to sound noobish but i'm not very familiar with HID's)
Old Mar 4, 2012 | 08:54 PM
You can do just lows if you want, might be a good place to start and see how you like them. You can always upgrade the highs later.
Old Mar 4, 2012 | 09:01 PM
Hmm ok, i was thnking 5000k, did you need any of the other stuff? Harness, adapter etc...? If these work it'll be good, $30 instead of $50 for hopefully better lights.
Old Mar 4, 2012 | 09:25 PM
Most that I've seen are plug and play. I'm not 100% sure on the relay harness people say you need to use. I'm pretty sure you can just do plug and play on Montes.
Old Mar 4, 2012 | 09:27 PM
I'll probably order them tommorow and hope for the best.
Old Mar 6, 2012 | 09:45 AM
JaxJim's Avatar
I got real lucky when I went looking for replacement headlights - there were left and right genuine GM headlights on ebay - brand new!. I got each for $45 from different sellers (total $90). These were the second set I put on the car - the first was a set of cheap aftermarket lenses I bought in 2006. The cheapo aftermarket lenses looked good, but the pattern was really screwed up - if you aimed the low beams correctly, then the high beams would be way off, and vise-versa. I ended up setting the low aim and living with it until those ones got all cloudy. Sounds like you are seeking something even better than stock, which is probably a good thing if you drive a lot at night.
Old Mar 6, 2012 | 09:55 AM
Thats the problem i have, i have cheap knock off gm lights and the light pattern is just terrible, road is splattered with light that has no form what so ever.
Old Mar 7, 2012 | 12:17 PM
mwjames's Avatar
you could always get a set from the boneyard and try to use some of those cleaners to take out the yellowing and such. I've never used them but i've heard from a few people that they work fairly decent
kyle08
Aug 29, 2006 10:43 PM
mikeyB976
Jan 27, 2006 05:39 PM
ralphtrent
Oct 5, 2005 03:35 PM
big green dog
May 22, 2005 10:42 PM
dagibbo
Dec 12, 2004 09:51 PM
