Gas gauge problem
Old Apr 14, 2009 | 01:40 AM
Cereal_Killer's Avatar
Default Gas gauge problem
Like the title states, I think I'm having a problem with my gas gauge. It It will show one reading, and then out of nowhere drop a 1/8th of a tank, stay there for a while, and then go back up to some other reading. I've read around here that the motors on our different gauges can go out, but it still works so it isn't that, is it? Could it possibly just need to be re-calibrated or something? Any input would be greatly appreciated.
Thanks!
-Sam
Old Apr 14, 2009 | 07:08 AM
Hi `Sam,
Have you had the fuel pump replaced? If you had, or not, you might want to check all your connections to the pump, make sure the positive lead to tank is secure and also you got a good ground on the tank too. Sometimes when a pump is replaced if not installed right the float in the tank won't work right or is hung up, and thats why it won't register right amount of gas on the gage.
Sometimes it's just a bad fuel tank sending unit in your tank.
How many miles are on your Monte ?
Good Luck `Sam
Member's, your turn 2 help `Sam
on his prob...post it `ok
Old Apr 14, 2009 | 07:46 AM
our fuel tanks are known for their bad sensors. BowtieTech has a very nice write-up in another thread on how to replace the sensor through the trunk, instead of having to rip the whole tank out. Hopefully you can find that thread.
Also, a thing to note is never to fill your gas tank past it's point of being full. I know some people will pay for gas, and when it stops at say... $14.23 they will go all the way to $15.00 to "even it out"
That's bad for the fuel filter and other various parts. The car says enough for a reason haha
Old Apr 14, 2009 | 08:00 AM
Arrow Write up Thread link : )
Mike, Great post information, and good memory about
prior post of Super Member: BowTieTech (Steve Brown)
The Member's appreciate your's, & Steve's super
contributions to our Monte Carlo Family Forum
4-Sure.
`Sam, below is the super write `up Thread by BowTieTech
Steve Brown <~ Thanks `Steve
https://montecarloforum.com/forum/sh...ad.php?t=11915
Click on above thread link to view
Great Detailed post
Old Apr 14, 2009 | 08:49 AM
The fuel pump has never been replaced, no.
And I usually don't fill her up past half, and when I do fill her up don't top it off. Buuuuttt..... I bought it used with 68,000 miles on it, and for all I know the previous owner could've.
It now has about 78,000 miles on it.
Anywho, I'll check out the sensor in the next few days, as well as the connections to the fuel pump.
Thanks guys!
ladybridgeport
May 29, 2020 08:20 AM
Hiperguy
Jun 21, 2013 12:02 PM
iMSeRiOuS
Jun 21, 2010 09:08 PM
phal
Jul 21, 2008 08:41 AM
BeachBumMike
Jul 30, 2007 11:53 AM
