6th Gen ('00-'05): Front & rear brake upgrade!
Old Aug 9, 2013 | 08:27 PM
Red Nightmare's Avatar
Compared the fbody with the wbody calipers this morning at work with some remans we got on the shelf. Wow what a weight difference! Its insane!
I'd say its safe to say the weight loss I'll get from the calipers alone will balance out the extra added weight from the new sway bar..its crazy!
Old Aug 9, 2013 | 08:31 PM
You are correct, it's simply two bolt holes on both brackets (not the caliper itself) that need drilled and tapped. Figure that.... FWD lower powered W-body cars have THINNER bolts holding the entire assembly then the full on F-body!! Funny....
You have to drill the F-body Bracket because the W-body uses a bigger bolt then the F-body..LOL
I used my stock rotors you can use stock brake lines all you need to do is bend the brake line bracket to give the line slack.
you need for drill/tap and parts you need to get for the swap. the pic is of a fbody
I installed 2002 Camaro calipers on my Monte sunday 12/30/2012
Love the looks an the stopping power , Its not hard to do, nice mod..
Here's a pic of the stock monte front pad on top
stock front camaro pads on bottom..Camaro pads are bigger..
Old Aug 10, 2013 | 06:41 PM
Ok! bought one of 2 brake caliper brackets from work. Waiting for the second one to come in, paying for it on Friday..
Decided to get them from work if I do have whoever is tapping the thread screw it up I get a free replacement..
Old Aug 26, 2013 | 09:49 PM
Did you install them yet ?
Old Aug 26, 2013 | 10:44 PM
Change of plans, Zippy had some calipers and brackets he is selling to me, returned the brackets. Way too damn expensive!
Old Nov 23, 2013 | 09:50 PM
2004DE_JR's Avatar
have you complete the swap? if so please tell us the results.
Old Nov 23, 2013 | 10:04 PM
I had no problems ..
MeanShwaMonte
Nov 8, 2015 04:00 PM
lucasmblanco
Jan 27, 2014 12:20 AM
volkerc
May 28, 2013 04:31 AM
davidk67
Aug 15, 2010 07:22 AM
SSmokybear
Nov 8, 2008 10:36 PM
