engine temp gauge not working
Old Dec 1, 2005 | 10:32 PM
01whitess's Avatar
Default engine temp gauge not working
All of a sudden it stopped working. Also, my fans have been running(c'mon, it's 40 degrees out). I'm assuming it's a sensor. Anyone had this same problem and where is the temp sensor???
Thanks for any reply!
Old Dec 2, 2005 | 12:36 AM
01whitess's Avatar
Default RE: engine temp gauge not working
found the sensor, looks like a PITA to get to but not impossible. hopefully this will solve my problem.
Old Dec 10, 2005 | 10:04 AM
merlyn7798's Avatar
Hello. Same problem just happened to my 2000 SS today. Fans stayed on after car was turned off. Tried putting key back in and cycling ignition switch to on position only (not to start car) and fans turned off...but temp guage (needle) still not working. Can you describe where the temp sensor is and how to get to it. Please. Thanks in advance.
Old Dec 13, 2005 | 02:31 AM
01whitess's Avatar
ok, sorry I haven't gotten to you sooner. Look below the thermostat housing, right next to the exhaust. It's not easy to get to. I had to use a long extension with a swivel. Be careful though I busted the old one taking it out. When you put the new one in make sure you have some sealant or teflon tape on the threads( you don't want to have to remove it aain). I had to keep putting the swivel in a certain position for it to turn without alot of tension on the sensor. The main problem is the sensor is angled downward.
*Be sure to disconnect battery for about 10 min and reset the computer. My gauge would not work until I did so.
Old Dec 13, 2005 | 02:33 AM
01whitess's Avatar
oh yeh, use a 3/4" deep socket also.
Old Dec 20, 2005 | 03:29 PM
2000 SS's Avatar
If your thermostat is bad, it will make your car have the same symptoms
iMSeRiOuS
Jul 31, 2017 07:40 PM
mercury2
Mar 14, 2015 02:03 PM
shallnot
May 27, 2011 09:44 PM
pinky71103
Oct 6, 2010 08:02 PM
mtc7
Mar 16, 2009 05:40 AM
