During gauge illumination check...
Old Feb 4, 2008 | 09:12 AM
isnms's Avatar
Default During gauge illumination check...
Is hot lamp suppose to light when key on?
Bulb is good.
Old Feb 4, 2008 | 10:09 AM
Default RE: During gauge illumination check...
As far as I know, all the warning lights are supposed to come on for a second or two to show you the bulb is working. If the light doesn't go out after a couple seconds, then I'd be worried.
Old Feb 4, 2008 | 10:15 AM
isnms's Avatar
That's what we were fixing. Had to replace the seat belt bulb, turn the SES bulb to make contact, but the temp bulb does not illuminate. The bulb is good. The temp gauge works too.
Old Feb 5, 2008 | 09:33 AM
isnms's Avatar
All this to track down why one little bulb won't illuminate...[/align][/align]But I like all my gauges and system information to work [/align][/align]The bulb is suppose to illuminate at bulb test. The trouble shooting doesn't give many options.[/align]1. check bulb and connection[/align]2. replace instrument cluster. [/align][/align]http://i80.photobucket.com/albums/j1...eschematic.gif[/align][/align]This from GMP/98-WC-1[/align]
Old Feb 10, 2008 | 04:41 PM
isnms's Avatar
I performed the test for the gauge:
1. Disconnect the engine coolant temperature (gauge) sensor connector.
2. Connect the instrument panel tester tool J 33431-C between the engine coolant temperature (gauge) sensor harness connector terminal C and ground.
3. Set the tester to 44 ohms.
4. Turn the ignition switch to the RUN position.
Only I used a 47ohm resistor to connect terminal C to ground and it Passed.
The gauge rose to HOT and the light lit.
Don't know why it doesn't come on at bulb test but it dose function properly.
bowtiebandit23
May 9, 2014 12:48 AM
superrod29
Mar 23, 2010 09:22 PM
White05LT
Feb 14, 2009 02:28 PM
biggriggs
Nov 11, 2008 08:55 PM
BeachBumMike
Feb 14, 2007 10:07 AM
